Seth Thomas Ogee
Tony Ambruso
Dec 2, 2005
734
www.azclocks.com
Got a S. T. Ogee from 1863. It's the 29.5" model shown in Tran Duy Ly vol.2, page 650. Unfortunately, it is missing its weights. It has a harp or Lyre-shaped 8-day movement with an alarm. The movement is numbered 3063 on page 981 of the same volume of Tran's book.
I have had up to 3.5 pounds on the strike side, but it didn't work properly. The movement is clean but unlubricated. Of course, I could experiement after I lubricate the movement to determine what the clock works with, but I wanted to know the correct weight for the clock. The time side works with 2 pounds.
The movement is identified on page 50 of the Clockmakers'Beat Book as
Seth Thomas 8 Day Harp Mov. Wt Driven T&S
Front Plate: ST Logo Bird also 18 on leg
(mine has 16) but the wheel count is correct and unique to this movement.
12,774
987
Tony,
Usually 2 to 2 1/2 pounds will work, assuming the clock is in good condition. Check the pullies at the top and inside left of the case. These little babies, though simple, can cause some really odd problems.
Merritts had some nice looking replacement weights lately. Evidently they are cast in very fine oiley sand, or dumped into oil while still hot. The finish is a smooth dark color and they look very much like an old weight.
lpbp
NAWCC Star Fellow
NAWCC Life Member
Aug 25, 2000
2,938
50
Eight day OG's take a weight that is about 7 pounds, the ones you have sound like they are for a 30 hour.
44,264
1,346
Not uncommon for the time side to run much lighter than the strike, but to get the same "look" they overpowered most of them.
Topic related ad experiment
160,781
1,394,984
82,834
machv5
1,099
2,778
