Seth Thomas Octagonal Wall Clock
Discussion in 'General Questions' started by rgmt79, Apr 18, 2017.
  1. rgmt79
    rgmt79 Registered User
    Jul 23, 2016
    64
    For my new restoration project, I have just purchased what was described as a Seth Thomas Octagonal Wall Clock from ebay http://www.ebay.com/itm/seth-thomas...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
    Although the movement has an ST stamp on it, there are no other markings on the movement or anywhere on the case. The size of the clock is 26" in length with a 10" dial face. I have done some research and cannot find this size combination or the design of the dial surround anywhere. The dial face is paper and may have been glued over the original painted dial (typical for this type of ST clock) and you can see that it is slightly off centre.
    Also, not having worked on an American movement before, I cannot be sure that all the parts are there (further photo's attached) and the pendulum does not seem to belong to this clock.
    Any comments would be appreciated.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Thank you,
    Richard
  2. Kevin W.
    Kevin W. Registered User
    20,158
    You have your work cut out for you. Its a nice looking case.
  3. Willie X
    Willie X Registered User
    8,005
    25
    It's Japanese. These were about 3/4 scale copys of American wall clocks made for use in Japan. Much later (1970s ?) they were imported into the US in large numbers.
  4. rgmt79
    Jul 23, 2016
    64
    Thanks Willie, the movement was made in Japan too? Any idea on age?
    Richard
  5. Steven Thornberry
    Jan 15, 2004
    17,650
    I believe Willie is right. What does the "ST" logo look like? IT might be that of Seikosha or another Japanese manufacturer. The double mounting feet on the movement and the metal discs between the mainsprings and the great wheel suggest oriental origin.
  6. rgmt79
    Jul 23, 2016
    64
    would you like to expand on that Kevin?
    Richard
  7. Kevin W.
    20,158
    Just meaning a restoration usually is clean, bushings assemble oil, lots to do. Asian clocks, Japanese are well made, i have a few of them.
  8. rgmt79
    Jul 23, 2016
    64
    Thanks Steven, photo of logo attached, maybe the 'S' is for Seikosha and not Seth?
    [​IMG]
    Thanks,
    Richard
  9. Steven Thornberry
    Jan 15, 2004
    17,650
    Yes, that is Seikosha.
  10. rgmt79
    Jul 23, 2016
    64
    Ok Kevin, I will clean the parts of course and then I will be able to see what more needs to be done...at first glance I think the bearings are ok. I need to know if all the parts are there...and as I said I don't think the pendulum is correct for this movement. What do you think?
    Thanks,
    Richard
  11. Kevin W.
    20,158
    If the pendulum works, i would just use it, but i dont think its original to this clock, nice looking Seikosha clock.
  12. rgmt79
    Jul 23, 2016
    64
    Hi Kevin, the pendulum rod has the wrong fitting. The suspension rod has a hook on the end (Seth Thomas style). I need to try and find out what the original pendulum looked like and then find a replacement...any ideas?
    Thanks,
    Richard
    [​IMG][​IMG]
  13. rgmt79
    Jul 23, 2016
    64
    I have just done some research on this forum and the pictures below match my movement and I guess this is the pendulum I'm looking for...any ideas?
    [​IMG][​IMG]
    Attached Files: Download all post attachments
  14. JTD
    JTD Registered User
    Sep 27, 2005
    3,863
    12
    These come up from time to time on ebay. Or you can by a new bob and stick (cut to size) and hook and make a new one.
    JTD
Similar Threads - Seth Thomas Octagonal Forum Date
Seth Thomas Drop Octagon, 8" Model -- What's the date of the clock? General Questions Aug 4, 2016
Seth Thomas Drop Octagon query General Questions Dec 5, 2014
Seth Thomas Long Drop Octagon Time Only Movement I would like Information Please General Questions Nov 27, 2014
Seth Thomas Drop Octagon that I saved... General Questions Jul 20, 2009
