Seth Thomas Movement
buzmarek
Oct 31, 2006
49
I have a Seth Thomas works that is stamped with a ST inside of a diamond with a circle around it and the #890. It is in a black Mantle Adamatine case.
Can anyone tell me if this is a part # or is it any indication of age?
Just getting into doing the cleaning and repairs on my own clocks and would like to know more about determining the age.
Thanks Buz
R
Richard Haliburton
Movement #. Seth Thomas clocks can sometimes be approximately dated or dated by movement #.
Another tool used in identifying them is the location made , Thomaston,
' Plymouth Hollow , etc.
The Tran Duy Ly Seth Thomas Guide , "Seth Thomas Clocks and Movements" would be good for you to have.
Rich
lpbp
NAWCC Star Fellow
NAWCC Life Member
Aug 25, 2000
2,988
65
This number is the movement type. The 89 movement was the most common movement used in the Adamantine cases, yours if you look closer is probably an 89C, or D.
Larry Pearson, FNAWCC* #35863
lamarw
Jan 5, 2002
1,643
74
Lake Martin, Alabama
I suspect the number you are referring to (#890) is actually movement # 89D.
If so, Ly's publication indicates it was in catalogs from 1901 thru 1936.
buzmarek
Oct 31, 2006
49
After taking another look at the movement it is clearly marked 89 C.
Would this date it to the early 1900's?
Buz
Randyd
Dec 2, 2004
104
Buz,
If your ST case is a black Adamantine it may be dated on the bottom. The numbers of the year would be reversed, the year 1896 would be 6981.
Randy
mbegalla
Nov 23, 2008
144
Florida
HELP...Seth Thomas movement identification
:confused:does any fellow member know what calendar movement went into a Seth Thomas hanging office number #7..it is a time only movement..I need to locate one for sale, or know what specific movement to look for, thanks to all you guys out there!:confused:
169,732
1,481,409
49,125
Nersinho
2,965
