Seth Thomas Mark I Deck Clock
Discussion in 'Clock Repair' started by wbranko, Oct 31, 2019.
  1. wbranko
    wbranko Registered User
    Feb 1, 2004
    388
    I'm repairing one of these and have a number of issues, however here is question #1.
    I opened the mainspring barrel and was greeted by a REALLY BAD smell. Nothing like the ghost of oil/grease past to visit the shop on halloween! After removing the spring and cleaning, I measured it as follows:
    5/8 in wide
    .011 in thick
    about 89 in long
    It looked a little set (probably the original from 6/43), so I went to my trusty Timesavers and Merritts catalogs. Nothing in there like these dimensions. Now, I know there are LOTS of these out there. What is everyone using for a replacement spring? The closest I found was Timesavers 16806:
    .63 in wide (OK)
    .018 in thick (probably way too strong?)
    96 in long (probably OK)
    Anyone have a better solution? Or know of where the exact replacement might be?
    I'm toying with the idea of using the old original?
    Ideas?
    Thanks!
    Bill
  2. Uhralt
    Uhralt Registered User
    3,855
    386
    This one for a Chelsea ships clock might work:
    No 34025 16.6 x 0.28 x 2135 mm. It's the closest I could find. Make sure that the width will fit. It is a bit wider. Personally, I would try the old spring first. It may work well enough.
  3. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    739
    27
    Retired Military
    Hampton, Georgia
    You said it looked a little set---even if it were a lot set it would probably work. Give it a try.
  4. shutterbug
    40,799
    728
    I agree. The spring you have is likely much better than a new replacement might be. Mainsprings are RARELY the issue when clocks are having troubles.
  5. wbranko
    Feb 1, 2004
    388
    Thanks to all...I will grease and reinstall the old spring as suggested!
