Seth Thomas mantle clock hands won’t manually move
Discussion in 'Clock Repair' started by Angeltech, Jun 13, 2019.
  1. Angeltech
    Angeltech New Member
    Jun 12, 2019
    Hello, I recently purchased a Seth Thomas adamantine mantle clock(89c movement). The clock hands move normally when the clock is running but the hands won’t budge when I try to manually move hands to set time/chime. Therefore, I can’t set the time or chime. Is there anything I can do to get hands to move manually? I bought the clock cheap and don’t want to put a lot of money in it by having it repaired by a pro if possible. Any help appreciated and sorry if posted in wrong place.
  2. R&A
    R&A Registered User
    Oct 21, 2008
    4,058
    75
    Your going to have to pull the movement out and see what the problem is
  3. wow
    wow Registered User
    Jun 24, 2008
    3,316
    123
    Retired Music Minister
    Pineville, La. (central La.)
    Welcome Angeltech. There is a clutch type set-up which allows the hands to be set without the wheels moving. I suspect that the spring tensioner is rusted and corroded so it does not slip on the arbor, or someone has soldered it for some reason, or who knows what is happening. Like R&A suggested, you will need to remove the movement, take some photos, and post them so we can see what is happening.
  4. Willie X
    Willie X Registered User
    11,294
    507
    My guess is that the two brass gears just behind the front plate are frozen together. Yes, a good take apart service will be needed. Virtually no clocks are maintained in good condition, nearly all are way way past due for a proper service. Willie X
    disciple_dan likes this.
  5. shutterbug
    39,689
    534
    The 89 is a very common movement. You might be able to get a replacement movement on Ebay .... but you're buying a pig in a poke so to speak, so read the descriptions carefully.
    I noticed one that has been rebuilt at a better price than I would be able to do it for. Something like that might be an option.
  6. Angeltech
    Jun 12, 2019
    Thank you everyone for your replies. I will take the clock apart and post photos.
