Seth Thomas Mantel clock help
Discussion in 'General Clock Discussions' started by Tim Fitzgerald, Jul 27, 2020.
  1. Tim Fitzgerald
    Tim Fitzgerald Registered User
    Jan 2, 2016
    751
    478
    Artist
    Oak island North Carolina
    Can anyone point me to instructions on how to sync a Seth Thomas mantel clock time and strike.
    Most appreciated
    timFitz
  2. TooManyClocks
    TooManyClocks Registered User
    Feb 6, 2019
    116
    35
    Assuming it’s a time and strike clock, not chiming, I usually move the hour hand if it’s somewhat close to the hour last struck. Or I might open the back, reach in with something small and lift the count wheel lever setting off the strike sequence until it agrees with the correct time.
    If the minute hand is at the bottom when the clock strikes the hour, move the hand quickly forward past the next strike until the hand reaches the bottom again before the clock has a chance to strike. Or remove the hand and move it where it needs to be.
    Hope this was helpful
    John
    Tim Fitzgerald likes this.
  3. Isaac
    Isaac Registered User
    Aug 5, 2013
    811
    125
    Student
    The hour hand is friction fit and will not hurt the clock if it is turned to the correct hour.
    Another method to fix the strike (should it strike the hours out on the half hour) is to advance the minute hand 3 minutes before the top of the hour. You should hear the strike train briefly run and then lock again. Move the minute hand backwards 5/10 minutes, and let the strike train run. You may need to adjust the hour hand to match the number of strikes.
  4. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,899
    622
    If the mainsprings just wound down unequally, a re-sync should be all that's necessary. If you find that the clock is occasionally getting out of sync for no apparent reason, you'll need to investigate further.
  5. Steven Thornberry
    Jan 15, 2004
    22,110
    1,033
    Ne’er do well
    Here and there
    Tim, can you post pictures of the clock and movement?
  6. Tim Fitzgerald
    Jan 2, 2016
    751
    478
    Artist
    Thanks everyone I got it straighted out :)
