Seth Thomas Helmsman
Discussion in 'Clock Repair' started by wbranko, Aug 26, 2018.
  1. wbranko
    wbranko Registered User
    Feb 1, 2004
    388
    I just finished putting a Helmsman back together. I took the center wheel out to do a bushing and apparently when I put the strike trip mechanism back on the center wheel, I was a little off. It strikes at one minute past the hour and one minute past the half hour.
    Rather than taking the clock apart and adjusting the strike trip mechanism, can I slightly move the setting point on the minute hand. See pictures...it appears to be adjustable...but it appears to have been staked? Is this adjustment possible? Is it wise? If so, how do I do it without breaking the minute hand?
    Thanks!!!
  2. shutterbug
    40,767
    720
    What kind of mechanism sets the strike up? If you have a J hook, it can be spread just a fraction to take care of the issue.
  3. Uhralt
    Uhralt Registered User
    3,841
    379
    Yes, the collet is adjustable. Insert a small square file if you have one. If not, A small screwdriver put in diagonally will also work. Hold the file in one hand or secure it in a vise. With the other, grip the minute hand as close to the center as possible and turn it into the desired direction. Be careful not to bend or break the minute hand.
  4. wbranko
    Feb 1, 2004
    388
    Shutterbug and Uhralt,
    Thanks for taking the time to reply! It is a Hermle mechanism, so no J-hook. However, Uhralt hit the nail on the head. I put a square file in my vice and carefully hand twisted the minute hand. I turned just enough to be right on target! I'm good to go!!!
    Thanks to both of you again!
  5. Uhralt
    3,841
    379
    Great it worked out for you!
