Seth Thomas face removal need help.
turboflyer
Feb 17, 2016
222
39
I posted this of face repair but it’s a little vague.I am trying to remove the dial to fix some dents. I was able remove the mounting plate but to no avail. The dial is affixed and I do t know how. It is a gift to my sister and she is leaving Friday.
could sure use some help. Thanks
E397351F-31C7-4D7D-8C7A-42B9BAE9F91B.jpeg 92B720A7-F95E-411D-AA58-2FA238222C04.jpeg 2FEF1072-DEE2-44A6-B481-BAD0D14A98EE.jpeg 821CC1FE-82EC-4D2F-9C6E-F056902B4207.jpeg
14,055
1,495
I would recommend that you leave the dial as is.
Plain brass can be straightened by a pro; they know exactly how to use heat and dapping blocks to good effect. They probably wouldn't touch anything painted, like you have there though.
turboflyer
Feb 17, 2016
222
39
The white plates are fixed to the brass plate by some means. Very thin material. If I can separate the two I feel confident I can make it better. Well that is a guarded confident.
14,055
1,495
If it is a separate piece, it's glued on. They drop off on their own sometimes ...
Recommendation remains the same.
:) Willie X
Reactions: Grant Perry
46,703
1,911
The clock appears to be a modern reproduction of an older design. Everything looks good, so I would also vote to leave well enough alone. It's a chiming clock, so the likelihood is that the movement was made in Germany.
turboflyer
Feb 17, 2016
222
39
It’s for my sister. I guess the best thing is to wait for Willies pic to happen. I will give her a warranty so when it falls off I will fix it
14,055
1,495
If you don't say anything, she may not even notice it! Willie X
Reactions: turboflyer
166,153
1,447,488
86,700
B_Lac
2,883
