Seth Thomas Adamantine date?
Discussion in 'General Clock Discussions' started by bangster, Apr 20, 2014.
  1. bangster
    bangster Moderator
    19,755
    414
    Can y'all give me a date, and maybe a model, for this nice Adamantine ST mantel clock?
    Tnx.
  2. Steven Thornberry
    Jan 15, 2004
    22,094
    1,029
    Ne’er do well
    Here and there
    #2 Steven Thornberry, Apr 20, 2014
    I found no pre-xact match in Tran, but the Chandos from the 1904 catalogue is close. Mahogany adamantine finish; half-hour strike on cup bell, hour on cathedral bell. 5" dial; 11" high, 17" long at base. Different incising, different bases and pediment for the columns. No date stamp on the bottom, I presume?
    I wrote the above and then noticed what might be the remains of a model name at the top of the label, "ECT." Anything else to be gleaned from that?
  3. Steven Thornberry
    Jan 15, 2004
    22,094
    1,029
    Ne’er do well
    Here and there
    On the other hand (the left, and not the right), check out these links, one said to be the Shasta (on what basis, I cannot say) and one said to be the Black Hussar (so why ain't it black, like it seems to be in Tran? And I guess we might as well include the Prince, 1904 catalogue in Tran. It has a very similar case - again shown as black, it seems.
    Oh, and forget the ECT - it's DIRECTIONS, a very suspect model name.
  4. bangster
    bangster Moderator
    19,755
    414
    MIGHTY close. "Shasta" and "Black Hussar" seem identical. Maybe 'black' because the style is 'black mantel', regardless of color?
    Mine differs from those two only in the upper spandrel incisings. Is that enuf to make a difference in Model?
    And Date. Is '04 as close as we can come?
  5. Steven Thornberry
    Jan 15, 2004
    22,094
    1,029
    Ne’er do well
    Here and there
    I wouldn't sweat the incisings myself. Details can change from model year to model year, I suppose. And I'm not convinced that the clocks I linked to actually are the models they are called. They may be, but I don't know why they are called those models. As for date, I can't myself do much better. Probably pretty close, particularly since Tran shows a couple with the same basic case from that catalogue year. Like I said, I presume you checked the bottom of the case for a date code, such as 4091 C, or the like.
  6. bangster
    bangster Moderator
    19,755
    414
    I hadn't but I have now. Here's what I see on the bottom. Can you make anything out of them?
  7. Steven Thornberry
    Jan 15, 2004
    22,094
    1,029
    Ne’er do well
    Here and there
    Not really. All I see appear to be scratchings of some sort. What I would expect to see as a date code would be more like the attached, which can just be made out as 8881 E, May 1888. But you don't always find the date, and at some point ST stopped using it.
  8. bangster
    bangster Moderator
    19,755
    414
    Ok, thanks much.
  9. Scott H
    Scott H New Member
    Jul 24, 2020
    I just aquired a very similar clock except in Black, the etching in the wood is similar but slightly more geometric and the base that the columns rest on has a faux marble finish, the only marking I have found is 4 1/2 stamped in the brass support when you open the back door. it looks like it had a date stamp but is illegible. I read on another post that the paper label changed in 1906 to the style you pictured here with the pocket watch shown. Seth Thomas stopped making Pocket Watches in 1915 so I would have to guess that mine, and probably this one is made between 1906 and 1915. If anyone knows of any other way to date this without the stamp please let me konw. Thanks
  10. Someone Secrer
    Someone Secrer Registered User
    Feb 11, 2020
    15
    I can tell you it is not a Shasta if that helps. I have a ST Larkin which is VERY similar to the Shasta.. has the rounded center and the 4 posts.
    It seems to me I have seen that one before and it was very near the same time frame. Mine is dated 1907..
    For what it's worth..
    Scott H likes this.
  11. Someone Secrer
    Feb 11, 2020
    15
    The pic didn't post.. sorry
  12. Dick C
    Dick C Registered User
    Oct 14, 2009
    1,665
    62
  13. Dick C
    Oct 14, 2009
    1,665
    62
    Reference the previous...I was editing the post and when I went to Save, gave me an error stating that the 30 minute time frame expired...
    So, I do not believe it is a Petrel as shown in Tran's book. However, if one focuses on just the inscribing there are a number of adamantine clocks that were from 1906 to 1915.
    An example is the Hull, circa 1915.
    Might help with dating.
