I have reassembled the movement up to installing the snail. Everything looks good, except that the snail turns freely. I don't think it is supposed to. What have I done wrong?
Here is the current setup. The snail wheel doesn't engage with anything. The wheel in the foreground (minute wheel?) does engage with a pinion at the base of the center arbor. I suspect the minute wheel is upside down. Before I take it back off, it would be helpful if someone would confirm that is what needs to be done.
Looks like disciple_dan is correct, the minute wheel looks upside down. I think I see gear teeth under the the larger wheel of the minute wheel, but it could be a reflection.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
