Hi everyone!
I have a Seth Thomas A101-000 electric movement from a Baxter desk clock. I've identified a part that I can't figure out why it is used. There is a spring that goes around the center shaft about 1/8" from where the rear pivot goes into the hole. This spring looks like it's cut the center shaft arbor completely through. From the photo looking in between the two plates you can see the center shaft is severed. You can also see that there is another grove being cut, maybe the original cut then the spring was moved. Anyway does anyone know what this spring is used for? It seems like it could help with centering the asrbor but being so close to the pivot hole seems odd to me. Also the pivot hole is not sloppy. I plan to drill a hole in the end of the center wheel arbor and install extension to the arbor and pivot. Can't see why I need to use this spring again. However this spring is shown in Tran Duy Ly vol 2 page 1007 illustration.
