64poncho
- Mar 24, 2023
- 9
- 1
- 3
- 63
- Country
Hello,
Have a mantle clock that I found at an estate sale. It has an 89M movement with a Sonora chime.
Tried to get it running with not much success. Oil was dried up, so I oiled it. The beat was very weak.
Would not run long and didn’t even run with the weight removed from the pendulum. Could get it moving if i added some finger pressure to the gear train. When I removed it from the case and inspected, there is good bit of play in frame, at the escapement wheel and the gear next to it.
Took the movement apart. Going to bush the frame as needed and clean and oil the mainsprings.
Gears and pivots on the time side, look very good. The strike side worked ok but has a lot of wear at the frame holes. Pivots also looked ok on the strike side. Upon closer inspection, found two bent teeth on the maintenance gear and the pinion on the stop/ warning wheel, has bent pins.
Was able to move the teeth back, doesn‘t appear they were cracked in the process. I want to replace the bent pins in the pinion. My question is how to retain the pins in the gear after drilling the peened over area.
Thanks, Ed
Thanks, Ed
