Seth Thomas 89 movement suspension spring replacement issue....
Don1965
Jun 27, 2021
102
11
55
I have a 89 movement from Seth Thomas. The original suspension spring has a kink and the pendulum wobbles and I wanted to replace it with a new suspension spring. Before replacement, the movement had a perfect beat and ran well. When I replaced the suspension spring with a new one from Timesavers, now the clock will not run at all and I cannot get a beat out of it. The suspension rod is not tight in the crutch. When I take it out and put the old spring back in, it runs fine again. Ideas? Thanks again! Don.
wow
Jun 24, 2008
5,701
705
76
Pineville, La. (central La.)
Is the new spring stiffer than the old one? Also, the diameter of the rod where it goes through the crutch must be such that there is only a tiny bit of slop there. Is the new rod thinner than the old one?
47,841
2,295
The crutch might have been moved to compensate for the kink in the old spring. You might have to re-shape it.
bruce linde
ADMIN / MODERATOR
9,546
1,604
oakland, ca.
clockhappy.com
why are we talking about the crutch? he just swapped springs.
i would want to know the thickness of before and after springs, and how flexible they are compared to each other. i would also want to know if there are any differences in thickness of the brass end pieces, where they’re fit to the suspension block and pendulum top… is the more slop w the new spring? less?
i would also check the free swing of the pendulum without being connected to the crutch… just to observe.
bruce linde
ADMIN / MODERATOR
9,546
1,604
oakland, ca.
clockhappy.com
the one way the crutch could be in play is if the dimensions of the new spring are not exactly the same and the crutch pin is hitting a different (and tighter) area of the crutch slot.
how about some specifics? exact dimensions of both springs? confirmation that crutch pin hits pendulum crutch slot at same location w both springs? closeup photos of both springs attached?
and, to anticipate Willie X ’s advice when he joins the discussion, just try swapping in another spring. :)
15,283
1,954
Most 89s have .003" thickness springs but some have .004" suspension springs.
I think they run a little better with the .003" spring.
I would guess that the crutch wire got bent somewhere along the way. Just moving the pendulum side to side will tell you what needs to be done.
Don1965
Jun 27, 2021
102
11
55
I wasn't able to do any research last night as I was sucking up water from my basement after a hard one day rain! Anyway, I do know that I have the .004" suspension spring from Timesavers. I have used it on my Seth Thomas Prospect 0 and Dana 3 and they work fine.
47,841
2,295
The original spring was bent. That would throw off the beat. I was opining that the crutch could have been bent to compensate for that, but now that a new spring that is straight has been inserted the beat will now be off the other direction because of the first compensation.
169,845
1,482,378
49,198
natee
2,965
