Seth Thomas 44AE movement
spxer
Jun 20, 2016
I just acquired a ST 44AE movement. Anyone know what case this movement belongs in? I tried to use the pend drop calculator to find the pend length, but the train is not laid out like the calculator examples.
bruce linde
Technical Admin
7,454
989
oakland, ca.
clockhappy.com
according to tran...
1917 catalog, distance rom center to lowest point of pendulum 11 7/8 inches and 3 7/8" between back of case and glass, hands not larger than 12"
wow
Jun 24, 2008
4,454
358
75
Pineville, La. (central La.)
They were used in several models. It’s an old movement. I think that one was in a Tudor around 1860-70. Others should be able to help with other models.
spxer
Jun 20, 2016
I have a Tudor. This movement is not like the one in my Tudor.
spxer
Jun 20, 2016
Maybe a short drop Schoolhouse?
44,263
1,346
It looks like the movement has been bushed recently, and congratulations on finding an old movement that still has the stop works intact!
12,774
987
They also went into black mantels. Those had a 3 5/8" stamp for pendulum length. This is actually the approximate length for the pendulum rod/spring assembly. IMO, you're looking at one of the best production clock movements ever made, often refered to as the 'big wheel" movement. Willie X
TooManyClocks
Feb 6, 2019
163
42
Here's my Tudor, with the same movement as in your photo. Mine is likely somewhat older, however, as mine has a Plymouth stamp on the movement and a Thomaston, Conn. label on the case.
Pendulum length is about 9 inches from top center to bottom of pendulum.
...and the stop works are still on this movement as well!
John
spxer
Jun 20, 2016
Here is the movement in the Tudor I have. The label is Plymouth Hollow.
Topic related ad experiment
160,739
1,394,847
82,828
iandb
1,099
2,778
