Seth Thomas #44 Movement
Discussion in 'Clock Repair' started by f.webster, Dec 11, 2018.
  1. f.webster
    f.webster Registered User
    NAWCC Fellow NAWCC Member Donor
    Dec 18, 2009
    722
    Service/Restoration of Clocks and Mechanical Music
    Louisville, KY
    I am trying to repair a (what I believe is) a Seth Thomas #44 movement. The one with the arm mounted to the inside of the rear plate. I believe that this arm acts as the warning lever when the movement begins the warning action. Right now the strike train does not strike because it get bound up on the locking lever. I have checked Steven Conover's Strike Train Repair however he does not address this arm or this striking movement. It appears that someone bent the daylights out of the arms. I have attempted to straighten them to their original shape.
    I sure could use a little help from my friends...thanks
  2. shutterbug
    40,783
    723
    I think that's a weighted return for the center J hook. Position it so it will force the hook back down with it's time for it to drop. It's been a while since I saw one, so I might be wrong too. I remember a thread not so long ago about that part. You could do a search.
  3. Willie X
    Willie X Registered User
    12,006
    698
    That loose sickle shaped brass piece is there so your clock can be turned backwards repeatedly at the hour to sync the strike with the hands. Don't go backwards past the half hour as damage to the half hour mechinism can occur, if it has a half hour bell. You will hear that little lever drop at about 20 till the hour. Willie X
  4. f.webster
    Dec 18, 2009
    722
    Louisville, KY
    Looking at this movement, I can't see where the warn stop lever is. I thought that the arm on the back plate must be involved. If it is to allow for strike adjustment, why is there a wire attached to the end of the count lever for that operation?
  5. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    5,956
    349
    I'm not clear as to what problem you're having, but if it involves the turn-back weight that Willie mentions, Dave LaBounty wrote up a page with illustrations on its proper operation. If your strike activating and regulating arms/levers have been bent up, things may have become a little "scrambled". See this link for more details on how the J-Hook should be able to pass under the minute arbor when the hands are turned Counter-Clockwise. The weight and it's flirt normally holds the J-Hook in the proper position so it doesn't have to rest against the arbor and can pass beneath it if need be. Dave explains it much better than I can... https://www.abouttime-clockmaking.com/downloads/What is it.pdf
  6. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    2,898
    251
    Science teacher, writer
    Lancaster, Ohio, USA
    THTanner likes this.
  7. f.webster
    Dec 18, 2009
    722
    Louisville, KY
    I knew thqt there was an answer somewhere. Thank you all.
    Once I have this straightened out, the question of the warn stop lever (or whatever) will become clear.
  8. Bruce Alexander
    Feb 22, 2010
    5,956
    349
    I knew that Dave had that explanation somewhere. Since he was responding to a question on the Message Board it probably is here too (or it should be). In any case, I was able to find it on his website. He certainly explains and illustrates it well. Since you were dealing with a severely "altered" arrangement to begin with, it must have been nearly impossible for you to make any sense of it all. Let us know if you have any more questions with your set up. We should be able to take things from here.
