seth thomas #3 threaded pins
Discussion in 'Clock Repair' started by Tclock, Apr 13, 2017.
  1. Tclock
    Tclock Registered User
    Apr 18, 2012
    52
    [​IMG]I am looking to have these made any ideas Thanks
  2. David S
    David S Registered User
    Donor NAWCC Member
    Dec 18, 2011
    5,791
    20
    Brockville, On Canada
    Try and again to get the picture to work.
    David
  3. shutterbug
    34,331
    Use the white camera icon in the reply window.
  4. Tclock
    Apr 18, 2012
    52
  5. Tclock
    Apr 18, 2012
    52
    [​IMG] Trying to have these made any ideas would be great they go into the Seth Thomas #3 to hold the movements in the bracket I'm sure they used them on other clocks. Thanks
  6. bruce linde
    bruce linde Technical Admin
    1,775
    if you can figure out what thread is used, you can possibly find alternatives on eBay... i recently purchased an assortment of such for < $20... odds of finding the exact ones might (or might not) be slim, you never know. knowing the correct thread, though, would mean you could come up with threaded rod and fit to knurled knobs to make work.
  7. upstateny
    upstateny Registered User
    Oct 2, 2015
    290
    I found some for a ST 113 listed on the bay but what you need is much longer.
  8. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    On pages 38 - 41 of the RandM Imports catalog they have a variety pack of tie down and seat board bolts. It is hard to tell from their catalog what the sizes and threads are, but they are quite helpful on the phone. Perrins has similar seat board mounting hardware, as does Timesavers. If you can figure out the thread and measure the bolt, I have had great success with all of them on a phone call.
  9. shutterbug
    34,331
    Quite common on Grandfather clocks too.
  10. Willie X
    Willie X Registered User
    8,065
    29
    Those knobs (if brass) can usually be taken off by clamping the shaft in a good vise and using crow's foot, or something similar) to tap them off. Then all you need is a length of mild steel rod the correct size and a die to cut the threads. Or, a length all-thread rod, if you can find it.
    I've redone a lot of these for German wall clock movement mounts. The brass ones come out fine but the ones made with spelter metal will often fall apart. The replacement screw, whether wood type threads, or machine type threads, can be epoxied back into the original thumb screw head. Be sure to put a few hammer dents or file marks on the tip that goes into the thumb screw head, so the epoxie will get a good grip. Solder is good too, if you are good at soldering.
  11. Tclock
    Apr 18, 2012
    52
    Thanks willie x the one I have is good I'm just trying to make some for a friend of mine who has a seth thomas # 3
Similar Threads - seth thomas threaded Forum Date
SETH THOMAS SHELF CLOCK cant hear the bell Clock Repair Monday at 5:34 AM
New Seth Thomas Essex - questions Clock Repair Oct 11, 2017
Seth Thomas with Jauch movement Clock Repair Oct 8, 2017
Seth Thomas no2 regulator, help needed Clock Repair Sep 5, 2017
Seth Thomas 124 Chime Stalling Clock Repair Sep 4, 2017
