Seth Thomas 124 chimer in tambour case fixer upper
Discussion in 'Clock Repair' started by Schatz70, Jan 15, 2020.
  1. Schatz70
    Schatz70 Registered User
    Oct 5, 2019
    111
    #1 Schatz70, Jan 15, 2020
    I bought this clock yesterday for $10 thinking that I was going to have to completely overhaul the movement to get it working, and that this clock would be good to learn on before tackling the nicer ST 124 I have. When I got it home, I was pleasantly surprised to find that it runs and chimes and strikes. Then I noticed that there is a big chunk of wood missing out of the bottom of the case. So it looks to me like this project is going to be more carpentry than clock repair. I see strong evidence that this clock has been dropped - the missing glass from the bezel, the chunk of wood missing from the bottom of the case, and the fact that the hinges holding on the back door are bent so that the door doesn't close properly. I have three questions I am hoping somebody can help me with:
    1. I'm thinking that the best way to repair the bottom of the case is to pry out the bottom panel that has a chunk missing and replace it, carefully measuring where to drill two holes for mounting the chime rods. Is that what you would do?
    2. Unlike my other ST 124, I don't see a chime shutoff lever. Does this model have one? The back plate of the hammer mechanism is stamped 124F and a date code 4610 which I think means October 1946.
    3. Does anyone know what the opening in the dial just to the right of the 5 is? There are three openings for winding the springs and another one up at the 12 for regulating the clock, but what is that other opening for?
    Thanks in advance for any help.
    Seth Thomas tambour 124 01 15 2020 004.JPG Seth Thomas tambour 124 01 15 2020 001.JPG Seth Thomas tambour 124 01 15 2020 002.JPG Seth Thomas tambour 124 01 15 2020 003.JPG
  2. Dick Feldman
    Dick Feldman Registered User
    Sep 1, 2000
    2,127
    79
    Colorado, usa
    The hole at 5 on the dial is for the chime shut off. Since 1946, someone has probably twisted the square off of the arbor and it likely is inoperable. That is what I usually find.
    It would be good to replace the floor in that case. When you do, make sure it is attached solidly. The floor acts as part of the sounding board for the chimes/strike. If the floor is compromised, the chimes will not sound as they should.
    Your new find runs, but does it run a full 8 days? If not, you likely are facing wear and the condition will get worse with use.
    Dick
    Schatz70 likes this.
  3. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    5,956
    349
    The Chime Shut-Off arbor is a weak point in the 124 design. As Dick said, you'll often find it sheared off since it turns maybe 120 degrees or so with a hard stop in both directions. The winding key has to be able to provide a lot of leverage and I think people just get used to applying a lot of pressure with it.
    Some folks will just square off the broken end of the arbor if there is room in the dial's opening to insert the key far enough. I prefer to "re-pivot" the Arbor to restore the appropriate length of the end.
    I would recommend that you post your photos in the Clock Case Restoration and Repair Forum for more detailed advice on how to best proceed with your project.
    I agree with Mr. Feldman. "Running" is good. That means all the critical parts are there. That's about all you can be reasonably sure of at this point.
    Good luck with it.
    Bruce
  4. Dave T
    Dave T Registered User
    Dec 8, 2011
    2,646
    69
    retired accountant
    NC
    I've got the same clock and almost the same case with the exception of the hole in the dial at 5. Evidently I don't have a chime shutoff.
  5. shutterbug
    40,741
    715
    I'll move this to the case repair forum until you get to the movement ;)
  6. Schatz70
    Oct 5, 2019
    111
    You're right - the square has been broken off (the arbor is just to the left of the nut in the first photo). I'm not worried about it - I like the chimes and don't plan to shut them off. If push comes to shove, I can reach in from the back and rotate the chime shutoff.
    I've started a run test to see how long it will go (second and third photos) - thank you for the suggestion. There are some key advantages of being the owner of this clock as opposed to working on a paying customer's clock - I don't have to worry about getting complaints about the chime shutoff not working, and if all I do to the movement is oil it and put it back in the case and it stops running after a couple of months, I can always take it out again and do a proper overhaul at that point. Call me lazy, but I'm not inclined to strip a movement that works. Maybe someone will disagree, but any time a clock is running there is going to be wear.
    Seth Thomas tambour 124 01 15 2020 010.JPG Seth Thomas tambour 124 01 15 2020 012.JPG Seth Thomas tambour 124 01 15 2020 011.JPG
  7. Schatz70
    Oct 5, 2019
    111
    In the first photo in my previous post, you can see that the mainspring boxes are riveted to the plate. When I do get around to servicing these springs, does anyone here know how to get the springs out? I saw one YouTube video of someone assembling this movement and he said that because of this you can't use a spring winder - you have to take out the springs "manually", but he didn't show how to do it.
  8. Schatz70
    Oct 5, 2019
    111
    Would it be possible to put this thread back in the repair forum? I've started another thread on this case in the case repair forum and I have some questions about the 124 movement I would like to discuss on this thread. Thanks.
  9. shutterbug
    40,741
    715
    Sure. I'll move it back.
  10. Bruce Alexander
    Feb 22, 2010
    5,956
    349
    Guess that depends on your Winder. I have an Ollie Baker and while I've only had to do one of these riveted set-ups so far, as I recall, I just gloved up and held the Assembly as I worked on each spring. These "Barrels" have to be handled differently than a typical capped barrel. There are many Threads on the topic. Here's one that I think may be helpful: ST 124 mainsprings. Let us know if you have any questions.
    Bruce
  11. R. Croswell
    R. Croswell Registered User
    9,411
    564
    and if the clock is dirty, and you oiled it, the abrasive dirt particles are now mixed with the oil and it will wear at an even faster rate until it is properly cleaned. Your game, your choice.
    The ST-124 springs are an issue riveted or not. The task is best accomplished if you make a "winding arbor" for whatever spring winder you plan to use. It is easy to just hold the spring box unit in one hand and wind the spring up. (It helps if your spring winder has a ratchet or locking device or someone to lend a 3rd. hand) Then slip the capture sleeve over the spring and unwind the spring and remove. The 124's springs are not very strong so it is easier than it sounds. Gloves recommended.
  12. Schatz70
    Oct 5, 2019
    111
    Thank you - you are always very helpful. What I'm picturing is that when it's time to put the spring back in the box, you first wind it onto the "winding arbor", capture the spring in the sleeve, remove the "winding arbor", let the spring down inside the sleeve, put the capture sleeve in the mainspring box, get it hooked in there, use your winder to wind it up, remove the sleeve, let the spring down and you're done. Do I have this right?
  13. R. Croswell
    9,411
    564
    when it's time to put the spring back in the box, you first wind it onto the "winding arbor", capture the spring in the sleeve, let the spring down inside the sleeve, remove the "winding arbor", , put the capture sleeve in the mainspring box, get it hooked in there, use your winder to wind it up, remove the sleeve, let the spring down and you're done. You get the idea.
  14. Schatz70
    Oct 5, 2019
    111
    Ah, I had a couple of things out of order. Better to make that mistake thinking about it rather than while actually doing it.
