Need help is setting the beat on a Seth Thomas 124 chime movement in a Tambour case. Since this is a blade type crutch instead of a wire it appears to me that you have to be able to get to the escapement to adjust it, but I am not sure.
Is there a way to set the beat without removing the movement from the case? Certainly access to the top of the movement is limited by this case style.
CP
CP
