After a day attempting, I surrendered and decide to ask for help. My little Seth Thomas 120 strike seems hard to set. The gathering pallet with the rack at rest on the rack hook has the pin around two o'clock, free from the rack. The hammer tail is not jamming into the hammer lift star. The gathering pallet is not yet in it's definite position, by the way the sequence seems correct the strike work. Nevertheless once in a while when the locking lever sets free the locking pin, this would not stop at the warning lever, would skip it by about a couple of tenths of millimeters and make a few turns, then stops and the sequence goes on ok. This happens for both the hour and the half hour. It seems to me that the arc between the lifting lever and the warning lever is a bit large but I don't see a way to reduce it being the levers flat brass. I checked the star cam; it looks good with smooth surface. Is this only a matter of setting the gathering pallet in a different position? I tried to find a better one but with no results. Is there any thing I can attempt? I know I'm bothering the group quite often and maybe I'm asking to much to myself attempting things for expert and not newbie like me, but it sounds really a pity to have this Seth Thomas on the bench just for the strike.
Thanks a lot for your attention.
Andrea
Andrea
