sessions store reg suspension spring,
steve1a
Jan 6, 2018
99
Hi any info where you can buy a suspension spring or try to bend one up like it . I rather buy a replacement if i can ,
Kevin W.
23,599
705
65
Merrits, Timesavers have them.
17,495
3,210
You will have to make those bends in your new suspension rod. You can use a 5/8" dowel (or steel) rod to make the big curve and pliers to make the 90 degree bends where the curve stops. When you sight down the wire the top and bottom straight parts should be in alignment. The 'eye' at the bottom can be made using a similar method and a 1/4" rod.
Note, a good pair of large round nose pliers makes this job a lot easier and be sure to leave your new rod on the long side. You can always shorten it a bit if necessary.
Kevin W.
23,599
705
65
Ebay has the curved type, perhaps have a look on there.
Reactions: steve1a
Rod Schaffter
Mar 20, 2020
248
51
60
The straight rods from Timesavers can be formed using this jig...
EDIT; the link is to walmart dot com, but it apparently doesn't like the preview feature of the Forum
Reactions: steve1a
177,601
1,556,519
53,629
nicobirdie
909
3,058
Watch Inspectors by Kent
