Sessions regulator.
Paddypup
Jun 30, 2021
134
Hello. Got this sessions clock and noticed I’m potentially missing a piece.
pictures I’m posting.
1st one is image I pulled off the internet and others are my clock.
Question is the horizontal brass arm is missing from mine, what is this piece for and is it vital to running of the clock?
It’s running well now after a bath and new oil.
Many thanks.
D6108DCE-0E2B-4B06-A8D8-A78957ECD65A.png F7087AFE-C1AA-47F6-9E6B-4DEB484C4881.jpeg E36C153A-E083-43C1-85B7-88843FCD0BE3.jpeg 76822EFD-CF12-4EC1-BF7D-5A8B8EC06E5E.jpeg
Paddypup
Jun 30, 2021
134
That is the calendar spring unit that allows the calendar wheel to move at midnight but also holds it in place the rest of the time.
Hi thanks for responding.so the calendar aspect of the clock won’t operate correctly without it ? It seems to be a brass piece with nothing else attached
wow
Jun 24, 2008
7,274
1,447
78
Pineville, La. (central La.)
Can’t tell from the internet photo but the solid piece is supposed to have a spring attached that has a curved end that fits between the teeth of the wheel.
Paddypup
Jun 30, 2021
134
Yes I see a pin or something in the bottom of the brass plate. Like the calendar feature of this clock. Wonder if this would be a tricky piece to make
Paddypup
Jun 30, 2021
134
If anyone knows of a suitable part please let me know. Thanks for the help. Goodnight
Paddypup
Jun 30, 2021
134
It looks to be in two parts. If anyone has close up pics of an original one that would be great thanks
49,926
3,156
All you need is something against the wheel (usually the upper teeth) that prevents the wheel from free wheeling or turning backward.
Paddypup
Jun 30, 2021
134
Would it need a bit of tension behind it also? Like spring steel mentioned above ?
49,926
3,156
Just a thin piece of springy brass would work. A slight bend at the end would keep it from binding. You don't need a lot of power there.
skidog
Dec 17, 2019
26
17
71
I recently ordered a complete Sessions Calendar fit-up from Mile Hi Clock Supply part #79.454 cost $11.25. Proper fit and solved my problem.
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
Latest posts
Staff online
181,317
1,582,077
54,765
Hec Losame
3,126
Top
