Hi,
I have a mechanism made by Sessions. I took it apart, cleaned it, and put it back together. Gong train seems to be fine, but the time train seems not to have enough power. When pendulum stops, if I move it, the counting(terminology?) wheel does not seem to move. Then I wiggle things, and it runs for a little bit again.
One thing I am sure of is that great wheel(terminology?) on that train is loose against its arbor. I did find this thread on how to fix that:
mb.nawcc.org
but my question is: can a loose great wheel rob the power, since if I understand this correctly, it is moved by spring through a clicker, and clicker is still there, or do I have other big problems needing bushings?
Thanks.
Great Wheel Loose on Arbor: Best Way to Tighten?
I have a main wheel that is loose on it's arbor. Can I use a hollow punch to reseat it? Thanks in advance, Doug
Thanks.
