Actually it is far easier to drive shaft out of rotor removing shaft and worm gear in one piece for service. Back the gear end of the field/coil assembly on a block with a hole to allow shaft/gear clearance. There very often is a small steel washer on shaft under rotor, don't lose it. With the shaft and rotor removed you can peg out the bushings and dig the grime out of the recess around the bushing on the rotor end of the assembly, and clean the rotor and shaft/gear. I lubricate with automatic transmission fluid adding perhaps six drops internally to hopefully add some reserve to internal wick, and then some Moebius grease in recess around bushing on rotor end of field. There is very little to gain in trying to install bushings, very difficult to secure and align bushings, then broaching the holes creates chips difficult to completely remove. Install shaft/gear, washer, then gently drive rotor on to shaft, then test to verify alignment and hopefully quiet operation. These can soldier on for decades this way, though perhaps not absolutely silent.
