Sessions Electric Westminster Clock
Discussion in 'Clock Repair' started by hookster, Jan 3, 2016.
  1. hookster
    hookster Registered User
    Jan 14, 2011
    1,998
    Pharmaceutical Consultant
    Pottageville Ontario Canada
    I just overhauled a Sessions Westminster Electric clock, likely from the 30s. It is the type that was converted from the wind up, mainspring driven, one written up in Steven Conover's book, Chime Clock Repair. It has two synchronous motors, one to work the time and the other to work the strike and chimes. The original insulation was worn, so I rewired both motors and provided added insulation, as well as doing the normal servicing of all mechanical parts. It is back in the case and running fine. I have noticed that both motors get warm, but certainly not hot to the touch. Is this normal? Thanks for any input that can be provided.
  2. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    146
    deceased
    Synchronous motors do generate heat as they work, so yes, it is normal.
  3. hookster
    Jan 14, 2011
    1,998
    Thanks Harold. I rarely work on these, and want to be cautious from a safety point of view as they do appear to run on a full 120 volts, and are non grounded. As an aside, the movement was completely caked with old dried up WD-40 when I took it in, but luckily not the motors. PS. 'Happy New Year' to you and yours.
  4. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    64
    Most all of these synchronous motors get hot.
    They usually use from 3 to 5 watts of power AC.
    It obviously doesn't require that much to run a clock
    so that power goes someplace as heat.
    If they don't get warm, they are broken.
  5. hookster
    Jan 14, 2011
    1,998
    Thanks Tinker. Also has a slight 'thumping' noise from the time motor. Again, is this normal? By the way, I had an old dead motor of this type in my junk pile. I just took it apart and noticed that the coil wire is extremely thin, so it obviously doesn't carry a lot of juice.
  6. hookster
    Jan 14, 2011
    1,998
    Just figured it out. The rotating outer disk was a bit loose. Put a dab of Loctite on it. Thumping sound gone.
  7. David S
    David S Registered User
    Dec 18, 2011
    7,173
    236
    Brockville, On Canada
    Loctite? Loctite? Is my malware software not working :). Just kidding, I love the stuff and Happy New Year Hookster.
    David
  8. hookster
    Jan 14, 2011
    1,998
    Yepp, great stuff. As the old Brylcream ad used to say 'A Little Dab'il Do Ya'. Happy New Year to you as well. Hope to see you at our next Toronto Chapter meeting in May.
  9. bruce linde
    bruce linde Technical Admin
    5,765
    533
    oakland, ca.
    can someone point me toward a tutorial on how to do that?
    thx,
    b
  10. shutterbug
    41,133
    792
    If you lose the inside coil wire, you're sol. The outer one can sometimes be fished out and reconnected.
  11. bruce linde
    5,765
    533
    oakland, ca.
    ok, i've got the thing running... some of the wiring is just barely hanging on, though.
    i guess i don't fully understand how it works... the lower coil seems a bit far away from and not attached to the gear that drives the time side... how is that working?
  12. Uhralt
    Uhralt Registered User
    4,046
    413
    Pictures?
  13. bruce linde
    5,765
    533
    oakland, ca.
    i will post photos mañana... thx...
