Sessions clock with unusual stamp on plate
Discussion in 'General Clock Discussions' started by harold bain, Sep 30, 2012.
  1. harold bain
    Donor NAWCC Member
    39,950
    I'm working on this Sessions black mantel, looks like a Winchester, from 1921 in Tran's book. It has Lion heads on the side instead of what's shown from the catlaog picture. Has the Successors to E. N. Welch label often seen.
    The unusual thing is the stamp on the back plate of the movement.
    Anyone seen anything like this? The movement is trademarked Sessions, likely original to the clock.
  2. Willie X
    Willie X Registered User
    8,071
    29
    Harold,
    Seen a ton of those movements, got a few of them now, but I've never seen that mark before.
    That would be a good picture to indicate how much the springs should be let down for easy assembly/dis-assembly.
  3. harold bain
    Donor NAWCC Member
    39,950
    Yes, Willie, it's a very common movement. I took the picture just before taking it apart. Needed the usual half dozen or so bushings. I try to get about that much unwind when letting down loop end springs. Not enough or too much and it's much harder to re-assemble. And I always use wire to restrain them. The front plate has the usual trademark stamped.
  4. Steven Thornberry
    Jan 15, 2004
    17,819
    20
    #4 Steven Thornberry, Oct 1, 2012
    I'm sure we've seen that CE come up before in regard to Sessions clocks. As I recall, we reached no definite conclusions. I vaguely remember having had a clock with that marking, but I'm not sure I would still have it. Hey, maybe good old Charlie Eccles put the movement together.:whistle:
    Aearch on Sessions CE brought two threads in addition to this one. Here is one of those two, and in it is a link to the other.
  5. harold bain
    Donor NAWCC Member
    39,950
    Thanks, Steven. I had a closer look at this one, and sure enough it's also stamped in the wood on the bottom with the C E. So, these were made for a customer (CE), possibly as a giveaway clock. The mystery as to who CE was remains.
  6. f.webster
    f.webster Registered User
    Dec 18, 2009
    608
    Service/Restoration of Clocks and Mechanical Music
    Louisville, KY
    Thanks for this thread! I recently had a Sessions clock with the C E stamp. ...now I understand that marking better.
  7. Steven Thornberry
    Jan 15, 2004
    17,819
    20
    Maybe so, but it doesn't entirely satisfy. I would expect to find this sort of thing on a label, something like "Made Expressly for CE by the Sessions Clcok Co." I was wondering whether it was a quality control marking of some kind, but that doesn't satisfy entirely either.
  8. lpbp
    lpbp Registered User
    Aug 25, 2000
    2,561
    I have just come across a Sessions with the Ce mark, the dial is unmarked, but the case has the same trim as others and the gong base is typical. the plate layout is Sessions.
Similar Threads - Sessions clock unusual Forum Date
help id sessions mantel clock model & vintage? General Clock Discussions Apr 19, 2017
Making progress on my Sessions clock case! General Clock Discussions Dec 24, 2016
Sessions marking on rear of clock case? General Clock Discussions Dec 23, 2016
Sessions Mantle Clock Identification General Clock Discussions Dec 13, 2016
Sessions Clock General Clock Discussions Nov 7, 2016
