Sessions Click Spring
T.Cu
Sep 26, 2020
288
51
Well, thanks guys, lots of great information about clicks. I need this information.
I have had one "explode" in my hand, and man that was painful! I had to go in and lie down, I felt faint! And I'm usually pretty tough, but wow! :) (Especially as my hands were really cold, you know how that is when you bang your hand when it's real cold?) My finger had about ten small cuts, was numb in some spots but hurt like the devil in other spots, and was blue and swollen, and I had a "bone bruise" that lasted for months.
This was a while back, but if I remember correctly it was a double whammy, the click itself was broken in two, like the picture above, but I think the rivet also flew out. An experience to be avoided. It was a Waterbury "Black walnut extra gothic pillar" model where the other click had already been replaced. Shoulda known.
R. Croswell
12,699
2,492
www.greenfieldclockshop.com
Ok thank you Mr croswell did you use the rivet that came with the click?
As mentioned somewhere in this thread, the rivets that come with the clicks may fit the click, but seldom fit the hole in the main wheel spoke. I just make my own rivets. This is a different style click but the idea is the same. I usually ream the hole in the wheel spoke using the smallest Bergeon bushing reamer that will cut, then I ream the hole un the click with the next larger size reamer. I know exactly what size each reamer is and make the rivet accordingly. You want a snug fit in the wheel spoke and a loose running fit in the click. Make the shoulder part just a bit longer than the thickness of the click. You can then peen the rivet tightly in the wheel spoke and not pinch the click.
Jordan1939
Oct 6, 2020
36
24
Thank you i don't have the tools to make my own rivets that's the problem, and have never done it before.
49,940
3,164
You might have enough ;) Get a non-shouldered rivet from your local hardware. It needs to fit the hole in the click fairly loosely. Then measure from the broad end the thickness of your click. Use a file to reduce the size below that mark until it fits in the plate hole. Then cut it off about 1mm longer then the thickness of the plate and click together. If it's not perfectly round, it's OK. You'll insert the rivet and then 'peen' the narrow end until it spreads out and secures the click in the hole in the plate. Use light glancing blows and don't be in a hurry.
Jordan1939
Oct 6, 2020
36
24
You might have enough ;) Get a non-shouldered rivet from your local hardware. It needs to fit the hole in the click. Then measure from the broad end the thickness of your plate and the click together. Use a file to reduce the size below that mark until it fits in the plate hole. Then cut it off about 1mm longer then the length of the plate and click. If it's not perfectly round, it's OK. You'll insert the rivet and then 'peen' the narrow end until it spreads out and secures the click in the hole in the plate. Use light glancing blows and don't be in a hurry.
Would that be making a shoulder rivet?
Jordan1939
Oct 6, 2020
36
24
In a crude sort of way, yes. Another option is to use the shoulder rivet that comes with the click and drill a new hole of the correct size on another spoke. There really is no way to do quality work without the right tools.
thank you do you make rivets for others or just for you?
49,940
3,164
Note: I revised my post above a little. I had the measurements wrong :rolleyes:
Note the quoted post, which I did not change, to see the difference.
Top
