dennispoli
- Jan 22, 2023
- 5
- 0
- 1
- 77
- Country
OMG! I never thought about that!If the clock is actually running as the picture seems to indicate, then someone has replaced the original weight driven movement with a spring powered movement and the Pullys no longer have a function.
Inside label says "eight day clock"There should be 2weights to drive the time and strike. Does the label say 30 hour or 8 day? Peter
I'm a newbie to this stuff.You should be able to see the two mainsprings on the big wheels. If it's running without weights then it has been replaced for sure. If you wanted to restore it to the correct style, you could probably find a donor clock. There would be strings running upward from the main wheels, around those pulleys you show, and a weight would hang from each side. It would likely be a 30 hour clock, requiring winding every day. An 8 day would require a harder to find movement, and heavier weights which would also be harder to come by.
In the current state, it has lost originality, and would not be desired by a collector. But if you like it, enjoy it for yourself![]()
Thanks guys! Will just work on the case which I think is nice.Nice information, Steven!
In your recent photo's, dennis, we can definitely see the mainsprings. According to what Steven has added, your case is probably the valuable part of the clock. Finding an original wood movement is going to be a real challenge if you decide to try restoring it![]()
