Senden Clock Factory
MuensterMann
Mar 23, 2008
1,419
I have an electric clock that runs on one C-sized battery. It is made by the Uhrenfabrik Senden from Germany, but does say Made in France. Anyone out there with experience with this movement? I apply the 1.5 volts to it, but cannot get any movement at all from the magnetic-mechanical portion. If I move a gear with finger, the magnetic-mechanical portion will move back and forth. Just wondering what the most common issue is with these movements and if repairable.
Thanks!
MuensterMann
Mar 23, 2008
1,419
I was able to apply the 1.5 volts directly and got it to move back and forth. However, the white plastic gear driven by the worm gear has 3 broken teeth. Without that gear with all its teeth - it will never drive the time. My money is on "that part not being available anymore".
MuensterMann
Mar 23, 2008
1,419
The movement is in a Semca electro-cell clock. The entire product has a clock and a barometer.
sophiebear0_0
Nov 5, 2012
93
19
Hi
I believe the type of movement is often referred to as a inverted Sully, or reverse Sully. If you search the Forum for "ODO" you will see a similar type of movement. With the ODO, the gearwheel is made of brass, rather than plastic.
The type of movement was pretty commonly used by companies such as Japy in their battery kitchen wall clocks dated aground 19760's - 1970's. These tend to use the plastic gear wheel. However I have no idea whether theses are interchangeable.
It might be worth taking your movement apart and see whether you could replace the missing teeth pegs with taper pins. As you say, the oscillating balance will not drive the gear train as things stand, so I'm not sure you would have much to lose by attempting a repair ?
Best regards,
Peter
Jessk09
Feb 27, 2020
177
23
You can look at another thread titled 1960s Urgo electromechanical clock not functioning . I think that clock has a problem like yours.
Tim Orr
National Membership Chair
Director
Sep 27, 2008
1,422
245
Boulder CO
Good afternoon, MuensterMann!
I have seen a movement like this one in an Odo clock (also from France) that I have. Mine has a brass gear where yours has plastic. I agree, probably going to be very difficult to find a replacement part. I do not know how hard it might be to make one. It looks reasonably simple, but that doesn't mean it would be easy.
I don't think finding a junk movement to cannibalize for parts is likely either. These seem to be rather rare.
Best regards!
Tim Orr
MuensterMann
Mar 23, 2008
1,419
Yes, it does seem like a simple part, but probably not easy. No spare parts. No used parts. The client says he wouldn't mind a quartz movement. I usually do NOT deal with quartz movements, but thought to give it a try. I am looking a mini-quartz and they provide many measurements, but not the shaft diameter. Does anyone know what the usual diameter sizes are? The present hole size in the dial is 0.2 inches. Thanks!
MuensterMann
Mar 23, 2008
1,419
Looking at all the options, I am not sure which to choose. The present hole in the dial is .2 inches diameter. The dial plate is quite thin. I am not sure about mounting. If anyone has experience with quartz movements, I would like to have some hints. Thanks!
Copyright © National Association of Watch and Clock Collectors Inc (A 501c3 non-profit corporation). All Rights Reserved.
