Here is a Self-Winding clock that raises some questions:
1. It appears that the friction clutch on the minute hand is too stiff and the synchronizaton coil is not strong enough to snap the minute hand back to 60. I can weaken the clutch action by loosening the minute hand retaining nut but this doesn't seem right. Is there some other adjustment here?
2. Running the synchronizing coil run on a higher voltage (4-5V) improves things. Is this proper?
3. When the synchronizing coil energizes and attracts its arm, how close to the coil heads should the arm get?
4. Picture 2 shows the minute hand reset arm, with a small hook pointing straight up. What's this for?
5. Picture 3 shows two fixed posts on the front of the front plate, below the seconds arbor. The larger one has a cross-drilled hole, as if something is missing here. What are these posts for?
6. Picture 4 shows what looks like an adjusting screw (but isn't) retaining the reset armature on its shaft. Is this just an ad-lib part?
Thanks,
Dave
Thanks,
Dave
