Experts on SWCC, please tell me about the clock I bought today at the flea market for $150, how it might have been used and if there is anything to be careful about.
It is a fairly small 120 beat SWCC wall clock with a 10" dial with seconds bit, in a rectangular wood case. The case is locked with two latches on the left side that can be opened with clock keys. On the dial below the usual company name is "PRR" and below that "118."
Inside is what appears to be a typical SWCC movement with a synchronizing coil and a very heavy round brass pendulum. A former owner has attached a small 3vdc power supply instead of batteries.
The clock seems to run perfectly and keep good time (so far) but is quite sensitive to going out of beat if it is not level.
There are no papers with this clock but there are two instruction labels on the inside of the door. One describes how to adjust the pendulum and the other describes the electrical contacts.
A small "authenticity" question. A former owner secured the dial with four new slotted round-head screws that have a bright plating. Would the original have been plated like this, or would they be regular steel or brass?
Thanks and regards
Steve
Thanks and regards
Steve
