Self winding clock using change in temperature to wind movement made by Karol Roman
Discussion in '400-Day & Atmos' started by janekp, Mar 30, 2016.
  1. janekp
    janekp Registered User
    May 21, 2011
    102
    #1 janekp, Mar 30, 2016
    [FONT=&quot]CLOCK with Torsion pendulum.[/FONT]
    Self winding clock using change in temperature to wind movement made by Karol Roman-engineer retired.
    Designed as a prototype of a hobby.[FONT=&quot]
    [/FONT]
    [FONT=&quot]Mr. Roman fascinated by clocks torsion invented himself his own clock with complications as a preface to something more serious.[/FONT] Of course we see here with modeled on structures known and respected in the world. This is just a prototype, not very nicely finished but work,work,work…
    He was already presented at several meetings in Poland.
    Please understand and patch to fix my technical errors in the translation.
    Technical description:[FONT=&quot][/FONT]
    [FONT=&quot] [/FONT]
    [FONT=&quot]
    The design, construction and performance of their own.
    Features: -
    The period oscilation balance - 32 seconds
    Uptake free - according to your wishes. Special feature - identical
    rest and boost work on both pallets.
    The cooperation escape whell and latch balance anchor in the range of about +/- 65degrees .
    The amplitude balance - maximum 680 degrees
    The drive from the spring drum. Power reserve ~ 100 days.
    Winding springs - either manually or by using the band tensioning
    changing the saturation vapor pressure of the medium -[/FONT] CH3 CH2 Cl -ethyl chloride. Similary as Atmos ,Reutter - clock power source with ethyl chloride gas.
    [FONT=&quot]- as a function of temperature.
    The scope of work of the winding 17°C to 25°C.
    Adjustment period rotations balance - two-stage by changing the active length
    pendant position and changing the radius of the additional mass relative to the axis
    Balance. The changing mechanism is inside the disc balance.
    Additional features: -
    1.Calendar lunar - ratio ensures the accuracy of the selected phase
    Moon 1 day for about 120 years. Form showing the phases of the moon less
    encountered.
    2.Month and day of the month to read on a rotating ring "annual"
    disposed around the shield. The system includes a variable number of days of February 28 or 29 days.
    Depending on the occurrence of leap years. Theoretically do not need to set
    by the year 2099. Whether a given year is a leap decides Adjustable
    setting discs placed of ~ 11.30.
    3. Days of the week shows the hand of the blade above indicate the phases of the moon.
    4. In the hinterland center of the disc is placed with a dial of 24-hour where you can determine (if anyone has a doubt) the time of day.
    5. At the time of 4.00 th an indicator of power reserve. It is required
    because that energy efficiency in the tension band
    air-conditioned spaces may be insufficient for
    sustain gait mechanism. The energy delivered mechanism
    a significant portion is consumed to drive the "complications".
    6. The hour has two stable positions relative to the hub, distant from each other by 30
    degrees. This allows you to seamlessly change the hour time change
    from winter to summer and vice versa.[/FONT]
    7.Material used por tube winding drum -tombak (~80%Cu + 20% Zn).
    8. protective glass -standart glas tube - for now is a makeshift
    9. Elinvar wire.
    10.[FONT=&quot]
    The energy of stretched spring comes the outer end (crown
    drum) transmission gait. The inner end of the spring cooperates with the
    differential which receives torque from the band tension
    and provides energy executive mechanisms "complications" in the moment
    the demand for it. With this solution, torque track
    gait is as smooth without discrete loads.
    blocade balance, during transport; is carried out by moving the lever
    located at the base. This improves the balance so that the upper
    portion of the axle abuts for the bench and the lower part
    will rest on the mechanism blocade .
    Setting an appropriate, with respect to the vertical position is possible by the clock
    inverting the two legs in the base.[/FONT]
    [FONT=&quot] [/FONT][FONT=&quot] the engine[/FONT][FONT=&quot] "thermo" a little too inefficient in air-conditioned rooms - summer on windowsill kneading on gait and complications (for there is no need almost 4 times more energy than the same gait). This is a prototype and should give a little more bellows and gears to reduce the charging spring[/FONT][FONT=&quot]
    Karol Roman 2.balans torsion pendulum I.jpg self einding  mechanismus  detal.jpg Scan0005.jpg regulation of  torsions-oscilation .jpg power  reserve  indicator .jpg P1000065.jpg P1000064(1).jpg P1000062.jpg P1000061.jpg komplikations .jpg escapment.jpg escapment .jpg date  changing mechanizm.jpg blocking  -blockage  .jpg 19.sam mechanizm bez lica.jpg termical  winding  -self  winding drawing.jpg [/FONT]
    2.balans torsion pendulum I.jpg 19.sam mechanizm bez lica.jpg blocking  -blockage  .jpg date  changing mechanizm.jpg escapment .jpg escapment.jpg komplikations .jpg P1000061.jpg P1000062.jpg P1000064(1).jpg P1000065.jpg power  reserve  indicator .jpg regulation of  torsions-oscilation .jpg Scan0005.jpg self einding  mechanismus  detal.jpg termical  winding  -self  winding drawing.jpg
  2. janekp
    May 21, 2011
    102
    Re: Self winding clock using change in temperature to wind movement made by Karol R
    More pictures
  3. whatgoesaround
    whatgoesaround Registered User
    Jan 22, 2008
    395
    science teacher
    south carolina
    Impressive!
  4. Burkhard Rasch
    Jun 1, 2007
    4,703
    105
    General-and trauma surgeon
    Twistringen
    #4 Burkhard Rasch, Apr 1, 2016
    that's the most interesting clock I've seen for years,congrats and Chapeau!Can You provide a Video? I´d like to see the escapement action!
    Burkhard
  5. janekp
    May 21, 2011
    102
  6. new_hampster
    new_hampster Registered User
    Aug 3, 2006
    95
    Motor and escapement is very similar to Atmos.
  7. Burkhard Rasch
    Jun 1, 2007
    4,703
    105
    Twistringen
    with all respect:No; this escapement is verry much like a verge or crownwheel escapement with additional "draw" to secure the lock and jewelled "flags" while the Atmos employs a jewelled dead beat anchor escapement.
    Burkhard
