A recently acquired Self-Winding Clock Co. round cased wall clock incorporates manual synchronization control in addition to the Western Union network sync movement attachment.
The round wood case with wood bezel hinged at the top has a turned profile resembling a "bean pot." The movement is the ordinary 140 beat "F" type with the sync attachment nestled inside the close quarters of the wood shaped case. Pendulum suspension is adjustable by a knob extending above the case. There is no identifying numbers stamped into the wood to identify the style. I would estimate the year offering as circa 1920.
The odd feature is the placement of a two-pole momentary contact leaf switch located in the lower left accessable only when the wood bezel is lifted. The left switch is used to force or initailly wind the movement the same as on many Self-Winding Clock Co. examples. The right switch uses the battery circuit to actuate the synchronizing magnets manually. Wiring to the leaf switch is original and neatly done.
I do not recall seeing or reading about any Self-Winding Clock Co. example with the "manual sync" control circuit although many collectors have added similar circuitry. Was this odd feature noted in any catalogs?
