seiko movement needed [qqz885a]
dennis
New User
May 21, 2022
My Seiko clock [qqz885a] quarts movement has no life at all. Where can I buy a new one or is this fixable?
roughbarked
Dec 2, 2016
7,509
1,379
I daresay you can fit many quartz movements. You do need the length of the spindle to be short enough to fit the clock and one that uses the same hands. Best way is to take the movement out and measure these things.
There are numerous sites you can find these replacement movements. Here is one of many in Australia. (because my search naturally looks in Australia first) However there are many and you should look around in your country for the best price perhaps but do make sure you get genuine Seikosha movements.
However, There are many small things that may stop such clocks that are relatively easily fixed by capable people.
Have you done any tests?
tracerjack
Jun 6, 2016
2,418
476
Lodi, CA
“qqz885a” appears to be the number for the clock. If you look for a number on the quartz movement itself, you should be able to find a replacement with an internet search. American and European/Asian quartz movements are not interchangeable, at least from my experience searching for a replacement quartz movement.
Rod Schaffter
Mar 20, 2020
233
47
60
I recently purchased a Seiko chiming movement to replace the movement in an old electric clock from Mt Vernon Clock Company, who sells on eBay. The key for you will be finding a movement that the existing hands will fit....
Hope this is helpful.
Cheers, Rod
dennis
New User
May 21, 2022
I have searched the internet for a replacement quarts movement for this clock but can"t come up with anything. This is a Seiko world time clock, probably about 40 years old. It has a gear coming out from the front of the movement that drives the time zone plates of the clock. The stem of the movement is not threaded, the hands are secured by snap rings. The movement is 2.1" x 2.1" x 1/2" thick. The stem is 5/8" long.
tracerjack
Jun 6, 2016
2,418
476
Lodi, CA
I see two numbers on your quartz movement; 44502C and 5119H. Did you look for a movement with those numbers?
dennis
New User
May 21, 2022
Yes I went to the internet with those two numbers in the battery case area and got no results. On E-Bay there are clocks like this for sale identifed by the qq2885a number and yes this seems to be the clock number but nuthing ties it to the movement. A fresh battery and clean contact points has not helped. I hate to open this movement up as I am 89 years old and my eyes are not what they were a few years ago.
tracerjack
Jun 6, 2016
2,418
476
Lodi, CA
You are right. I could find nothing after searching for a half hour. I could not find any quartz movements with that front drive gear. That world clock model by Seiko regularly comes up for auction on shopgoodwill.com. Most aren’t tested, but they are usually inexpensive.
roughbarked
Dec 2, 2016
7,509
1,379
This is a continuous movement. I think it possible that it hasn't failed as much as the lubrication is now glue and the rotor needs the fine magnetic dust removed from it. If you knnow someone who can do this then it may go. Have you put your best spectacles on and looked to see if the wheels try to move with a new battery?
Otherwise, you can still get continuous movements but you may need to drill a hole and use the old minute wheel from your world clock to make it work the same.
dennis
New User
May 21, 2022
I would like to thank everyone for all the suggestions on trying to get this clock working again. I will just keep my eyes open for a replacement movement that will work in this clock. Thanks again for all the help.
16,536
2,622
Seiko isn't an easy company to deal with but, if they have the movement, they will usually sell it to you.
If they don't have the movement, your chances will narrow to: fixing the old one, or buying whatever unknown like movement you can find. :(
Keep us posted. They sold a lot of these little clocks back in the day, so what you discover might help someone else.
174,358
1,523,538
52,183
minister
1,063
2,970
Last page
