Seiko Kinetic Battery or Capacitor?
Discussion in 'Wrist Watches' started by artbissell, Jan 25, 2020.
  1. artbissell
    artbissell Registered User
    NAWCC Member Sponsor
    Dec 4, 2009
    3,835
    417
    1979 startup ABCO Industrial Sales
    Boulder, CO Foothills
    Found I have an old good one that runs but needs a lot of motion use time to run normally. Most seem to have a replaceable lithium battery, but this one calls it a capacitor. It is useful as is. Are later models wth batteriy storage quicker chargers or are both actually batteries? This old model is all original maybe 20 years old? artbissell
  2. Kevin W.
    Kevin W. Registered User
    22,552
    377
    The newer capacitors do charge quickly and keep a constant charge. I changed a capacitor in my Seiko kinetic, its a older model and it runs fine. The older capacitors that were used in the kinetic watches i have heard , were not as good as the newer ones made today. I had a older Seiko kinetic and i sold it as when i replaced the capacitor no amount of arm movement would charge it. The one i have now when i check its level is usually around 4 oclock or slightly past.
  3. artbissell
    Dec 4, 2009
    3,835
    417
    #3 artbissell, Jan 25, 2020
    Thanks for your experienced good judgement. While my old watch may be slow to charge its 2 second hand jumps still provide nearly instant accurate time. and no need to replace a battery. art b.
    Kevin W. likes this.
  4. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    4,676
    460
    watchmaker
    If it is an older capacitor, you do need to change it because the older capacitors were capable of leaking.
  5. artbissell
    Dec 4, 2009
    3,835
    417
    #5 artbissell, Jan 25, 2020
    Good comment. I assume you mean electrical current leaking. There is no chemical leaking. After 2 days of wearing it is normally 1 second functioning. After near 10 years no use. AMAZING accuracy with no battery, quartz or spring power. art b.
    s-l1600.jpg Wrong photo will not erase.
  6. Kevin W.
    22,552
    377
    Perhaps the mod can remove the picture for you.
  7. artbissell
    Dec 4, 2009
    3,835
    417
    This is the old one.
  8. Kevin W.
    22,552
    377
    Too be on the safe side i would get it replaced.. It does not cost much the capacitor. And if you do watch work not difficult to install
  9. artbissell
    Dec 4, 2009
    3,835
    417
    I agree,. Will look for parts source. art B.
  10. Kevin W.
    22,552
    377
    Hi Art, Ebay has them. I bought mine from a supplier that gave me free shipping in Canada, a Ebay seller.
  11. roughbarked
    Dec 2, 2016
    4,676
    460
    watchmaker
    It is a replacable part. If it needs replacing it should be replaced.
  12. artbissell
    Dec 4, 2009
    3,835
    417
    Thanks again for your help. I am sure I was first owner to open this old $520. original list price junk watch and capacitor is probably original and running perfectly at one second rate with perfect registration. Notice ebay sales indicate it is popular and valuable. art b.
  13. roughbarked
    Dec 2, 2016
    4,676
    460
    watchmaker
    Well and good.
    Clearly the watch and capacitor have never been exposed to extreme heat. Which happens a lot in my part of the world.
  14. Roy Horrorlogic
    Roy Horrorlogic Registered User
    Mar 7, 2017
    382
    99
    I did one of these a couple of weeks ago. Unfortunately the "push to show power reserve" button doesn't work and although I've taken a look I can't see why without pulling the whole watch apart. In any case the power reserve with the new capacitor is considerable. Seiko have always made such good watches, and it's ridiculous just how little this model fetches. Here's a snap of mine, on its original bracelet. I detest metal bracelets in general but this one has a really well thought out clasp.
  15. artbissell
    Dec 4, 2009
    3,835
    417
    Looks like a good old one. Probably wiith same fine band, with switch I know nothing about. art b.
  16. roughbarked
    Dec 2, 2016
    4,676
    460
    watchmaker
    I did one recently as well. Did yours have a bit of apparently floating contact on the movement holding ring?
