Mechanical WW Seiko BellMatic Stem
Discussion in 'Watch Repair' started by Grant Perry, Jul 23, 2018.
  1. Grant Perry
    Grant Perry Registered User
    Jun 5, 2002
    1,393
    14
    Ottawa-Canada's Capital
    Hello,
    I have a Seiko Bell-Matic with a broken winding stem. It rusted/broke at the crown. Is there a parts listing that I can use to find a replacement?
    Thank you in advance.
    Grant
  2. Chris Radek
    Chris Radek Registered User
    Apr 13, 2014
    459
    141
    Watchmaker (now accepting new customers)
    Lincoln, NE, USA
    Assuming it's a cal. 4006A, the winding stem is part # 354805.
  3. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,493
    210
    watchmaker
    If it broke at the crown from rust, you need the crown as well.
    I wasn't aware of a different caliber than 4006. Thought that was the only bellmatic.
  4. Grant Perry
    Jun 5, 2002
    1,393
    14
    Thank you! It has 4006 and 6027 on the back of the case.
  5. Grant Perry
    Jun 5, 2002
    1,393
    14
    And 4006A on the movement.
  6. Grant Perry
    Jun 5, 2002
    1,393
    14
    Is there also a part # for the crystal, or is it simply replaced by size?
    Thanks again.
    Grant
  7. dAz57
    dAz57 Registered User
    Dec 7, 2011
    2,018
    watchmaker
    sydney Australia
    Seiko case numbers are always written as 4006-6027, not two separate numbers,
    Crown 55M22NS
    Stem 354805
    Glass 325T02ANS
    cradek likes this.
  8. Kevin W.
    Kevin W. Registered User
    21,652
    210
    They are nice watches Grant, is it yours.
  9. roughbarked
    Dec 2, 2016
    3,493
    210
    watchmaker
    I've got three or ids it four Bellmatics. Unfortunately they all have some rust in them. The first one I had given a new champagne dial and managed to lose it in a peach orchard. A few years later the farmer pushed out the peaches and found my watch hanging on a tree root. He gave it back to me but sadly it had got some water in through the alarm button. I've rebuilt it again from parts from one of the others. I wanted to rebuild it because I had added extra jewels in the first instance.
    Don't think anyone else has a 20 jewel Bellmatic.
  10. Al J
    Al J Registered User
    Jul 21, 2009
    551
    52
    Or he could dissolve the broken part of the stem out of the crown with an alum solution - I do this all the time to save crowns...
    Cheers, Al
  11. roughbarked
    Dec 2, 2016
    3,493
    210
    watchmaker
    Why is the stem rusty? Where did the water get in?
    OK yes replacing the seals my help but nothing works as well as a new crown.
  12. roughbarked
    Dec 2, 2016
    3,493
    210
    watchmaker
    I'm happy to send you all the old crowns I have replaced. They are ony junk here.
  13. Grant Perry
    Jun 5, 2002
    1,393
    14
    Hi guys,
    Thanks for all the help. I have ordered a new stem and crystal, but have yet to locate a crown. Roughbarked, I may take you up on your offer if I can’t find one. Thank you for the offer. It may not have rusted through, but there is rust where it broke. Wear and tear I guess.
    Grant
  14. roughbarked
    Dec 2, 2016
    3,493
    210
    watchmaker
    Seiko Australia, in their great wisdom tossed their spare parts away. I've tried for several crowns from several parts suppliers recently with no joy.
  15. Grant Perry
    Jun 5, 2002
    1,393
    14
    Hi Kev,
    Yes, it was one I got from Dan. Thought I would refurbish it. I had two before, but I think I sold them both to Mel.
    Grant
  16. Al J
    Jul 21, 2009
    551
    52
    You can mix up ma solution of alum and water (saturated solution, so as much as the water can take), put the crown in it making sure that the solution is in contact with the broken end of the stem. Every few hours, clean out the black material that will form as the stem dissolves, and put it back in the solution. Since the surface area is small, the alum will take some time to dissolve the stem, but if you keep making sure that the alum is in contact, it should be completely gone in a couple of days.
    Here's an example...
    Alum can be found in the spice aisle at the grocery store:
    You can see the black debris in the hole here:
    Alum is something I use often, for removing broken stems in crowns, in particular valuable vintage crowns that can be worth hundreds of dollars. But it also works well for removing broken screws in plates and bridges, and in this case dissolving away parts from a bridge that had rusted in place after the movement was flooded. You can see it working...
    Cheers, Al
  17. Grant Perry
    Jun 5, 2002
    1,393
    14
    Thank you Al,
    I have successfully used Alum in the past to remove dial hold down screws, and a jewel setting screw, but I wasn't sure what material the crown was made of and thought it may dissolve.
    Thank you for the confirmation. I think I learned that method on this board about 10 years ago. Maybe from you!
  18. Chris Radek
    Apr 13, 2014
    459
    141
    Lincoln, NE, USA
    I've also used this technique to get hopelessly stuck screws (and hinge pins, for better or worse) out of vintage gold eyeglasses frames. Heating helps a lot.
  19. Grant Perry
    Jun 5, 2002
    1,393
    14
    Well, I can only assume that the old stem is made of something that is not affected by Alum. After 3 weeks the only thing that has happened is that the remainder of the stem is clean and shiny. I have used Alum before on pocket watch screws with no issues, but it has no impact on this one.
  20. Kevin W.
    21,652
    210
    I have a Seiko Belmatic i bought from Mel, its a really nice watch. Hope you get the stem problem taken cared of.
  21. roughbarked
    Dec 2, 2016
    3,493
    210
    watchmaker
    I am fond of the bellmatic but they can be a bit complicated to reassemble.
