Seeking more bushing advice
Thurmond
Dec 14, 2021
14
58
Got my 1st bushing project clock all assembled (ST89). Running great!
Onto a Gilbert (stamped 373, movement id?) that looks to be a knock off of the ST89 but even more cheaply made. Appears like its had a hard life - many bushings will need to be replaced and lots of dirty oil all over the place. Perfect clock for me to continue practicing bushing replacement.
I'm wondering if I'm about to step into the deep end with this one (see pixs below). Specifically:
- Is the bushing (with red arrow pointing at it) going to give me trouble being so close to the edge of the plate?
- Is the bushing that has been peened 5 times into place going to be difficult to center and reem?
The pinions on these two locations are loose but not by a large amount. I'd rather leave them alone if there is a good chance that I'm going to butcher the clock.
I'm probably worrying too much - its a $25 flea market find that I bought as a practice clock, but I haven't lost one yet and would like to keep it that way.
Thanks,
Thurmond
wow
Jun 24, 2008
5,878
752
76
Pineville, La. (central La.)
Thurmond, I think you should go ahead and bite the bullet and do it right. That one in the second photo has been punched but it can be bushed. The punch marks may not all be removed but it can be bushed like any other bushing. All the rest look like normal bushing jobs. Just mark the direction of the wear and make your first couple of cuts in the opposite direction till the hole is round. Then just ream away. Are you hand bushing?
Reactions: Willie X
15,638
2,139
That first photo appears to be the motion works gear. No need to bush that one, it operates at about zero load and needs to be on the loose side anyway.
Most Gilbert's are easy to work on.
Thurmond
Dec 14, 2021
14
58
Definitely easier than that ST89. The coil springs (wires) have been replaced with leaf springs. And the mechanical linkages are all stamped steel (vs stiff bent wire rods acting like fishing hooks). Lots easier to disassemble without parts suddenly jumping out. I can see that re-assembly is going to be easy.
Any comments on the similarity between the Seth Thomas and the Gilbert? Did one company borrow the mechanical strategy from the other or this was just the way most manufactures made a striking movement?
Thurmond
wow
Jun 24, 2008
5,878
752
76
Gilbert’s are notorious for having cracked canon pinions on the main arbor causing the hands to slip. If yours is cracked, there are tons of threads on this forum about repairing it. Other than that, I find them pretty straight forward.
Reactions: Jonas
48,183
2,399
The problem with punches like that is that you can't be sure of the proper center. I can see that the edge of the plate is distorted outward, so the center might be also. After you get it bushed look closely at the gear to pinion alignment (depthing).
R. Croswell
11,236
1,307
www.greenfieldclockshop.com
I agree with Willie, the pivot hole at the red arrow would be challenging to bush and probably isn't necessary for the reason stated. Gilbert, Seth Thomas, Sessions, Waterbury, et al were all similar in design but not direct copies (as are several Japanese makes). Seth Thomas is one of the oldest American makers of brass movements so I'm sure that others "borrowed" some of his designs, but each maker is uniquely different. Gilberts and Ingrahams had a problem with cannon pinions cracking, Sessions had cheaply made clicks that fail more often, New Haven used a different strike control system, etc. All of the mass-produced models were made down to a minimal price and I can't say that any one was significantly better than the rest. Most lasted about 100 years before wearing out which is not bad. Many of the older wooden works clocks are still going after nearly 200 years which is even more amazing.
Thurmond
Dec 14, 2021
14
58
Thanks all for all the information ... and I feel like I'm on the edge of another big purchase.
The depthing tool seems like a necessary tool to perform 100% proper repairs - yes/no? It might be a little over the top for a clock of this quality/value but I'm getting the impression that I'm going to need it sooner or later.
I also inspected the cannon pinion for cracks and it appears to be fine.
I did notice two parallel grooves cut in a twisted fashion on the main arbor. Was this a cheap way to create the friction between the cannon pinion and the arbor?
wow
Jun 24, 2008
5,878
752
76
I have a depthing tool but seldomly use it. It is great if a bushing has been installed off center but I don’t use mine except where a mistake has been made.They are quite expensive. I would try to work toward a lathe and/or mill. Also a good spring winder and perhaps a bushing machine.
On the pinion, the small one is the one that usually cracks. We can’t see it in the photo. Check it carefully. Those grooves look like someone may have removed that pinion and made the grooves doing so:???:
Thurmond
Dec 14, 2021
14
58
Hi Will,
I think you are correct about the grooves. After running the parts through the cleaner, they are really difficult to see. I think some grit/debris may have been dragged through some old grease upon disassembly (dismantling?).
Not having seen the crack problem before, I'm not 100% where to inspect but I don't see any cracks anywhere under the loupe.
Thurmond
5,349
733
If the minute hand doesn't slip, no crack-you are fine.
Reactions: wow
wow
Jun 24, 2008
5,878
752
76
Hi Will,
Thurmond
View attachment 690220 View attachment 690221 View attachment 690222
Yep. Looks good. No crack. Someone must have replaced it already.
48,183
2,399
You can make a depthing tool from a door hinge. Do a search here for detailed information on how to make one.
R. Croswell
11,236
1,307
Steven Conover in his book, Clock Repair Skills, Chapter 12 "Using the depthing tool" describes how the depthing tool can be useful and demonstrates the shortcomings and limitations. Perhaps most importantly he describes a method to check if the depthing tool is accurate. After setting a bushing according to the depthing tool he commented, "I have three depthing tools, one of which is a prototype. None of the three tools passed the test.............The error I had made in placing the first pivot hole had been 'entirely' due to the fact that the runners were not parallel.............An accurate depthjing tool is a very effective one for our work, but a tool that doesn't have parallel jaws will cause problems.
I question whether the average home mechanic using ordinary hand tools can construct a depthing tool from a door hinge with sufficient accuracy to be of much use. The tips of the runners must be precisely the same distance apart as the center of the pivots being held in the tool. The "test" Conover described and attributed to Laurie Penman is to scribe a circle with the runner points on one, then turn the tool over and see if the runner points on the other end scribe the same circle. That of course proves nothing unless the holes for the runners were line-bored and parallel. I've read others who say that none of the currently available and popular depthing tools are accurate enough to be reliable.
Jerry Kieffer I believe described what is likely a more accurate depthing method for locating pivot holes using a Sherline mill. A good quality depting tool, if one can be found, may cost nearly as much as a basic Sherline mill and is only useful for one thing. Consider saving you money and put it toward a tool that will be used for many things.
Reactions: Willie X
Thurmond
Dec 14, 2021
14
58
Thanks everybody for the feedback and advice.
I agree that a depthing tool shouldn't be at the top of my tool list, especially since I don't even have a spring winder yet.
I like the 'Ollie Baker' type of spring winder but they aren't in stock anywhere. Timesaver will put you on a waiting list and will ship them as they come in. Wonder who makes them and why the lack of inventory. I suppose the generic answer is Covid and supply chain. Things are really getting bad if you can't even buy a spring winder ...
Thurmond
wow
Jun 24, 2008
5,878
752
76
Thurmond
Thurmond if you do a search on eBay for Ollie baker, there are four for sale now.
48,183
2,399
I'd be a bit uneasy with the spring hook, Elliott. It should be stronger.
Elliott Wolin
Nov 18, 2019
514
81
67
Williamsburg, Virginia
That hook is made out of incredibly hard, strong, and thick stainless (I think) piano wire. I couldn't cut it with diagonal pliers, it was harder than the pliers and put dents into its cutting edges. I had to use a grinding wheel to cut it. Bending it was not easy, either. It seems extremely strong to me. I suppose the act of bending it could have caused an incipient crack at the bend, though.
My thinking is that the force on the wire holding the spring is really not that much compared to the strength of the wire. But maybe I'll take your advice and come up with something obviously stronger/safer.
In any case, when I use it I wear heavy leather gloves and a full face shield.
15,638
2,139
Bugs is trying to prevent you from having an accident! I would listen, or you may just like to do your learning th hard way.:???: Willie X
171,040
1,493,319
50,085
Genda
2,967
