Seeking information on a mantel clock serial number
Discussion in 'General Clock Inquiries' started by Orafist, Mar 2, 2012.
  1. soaringjoy
    soaringjoy Registered User
    Feb 12, 2009
    7,240
    13
    Before you start adjusting the minute hand collet, try this.
    Move the minute hand to the point, where you get the 1st quarter chime.
    Adjust the collet then to that "quarter" after position.
    After refastening the hands, move the minute hand further on, until it
    reaches the 2nd, 3rd and 4th quarter chime and strikes the hour. Wait until each
    chime has ended, before advancing the hand again. Count the hour strikes.
    Then move the hour hand (it's a friction fit) to the time that had been struck.
    That should set the chimes in sequence.
  2. harold bain
    39,893
    I might have misread your problem. If it's chiming the halfhour chime at 3/4 hour, for instance, the minute hand can be taken off, and moved back 90 degrees. Since it's bushing is square, it can be put on at any 15 minute position.
  3. Orafist
    Orafist Registered User
    Mar 2, 2012
    35
    #23 Orafist, Mar 7, 2012
    the hands are held in place by what seems to be a bent pin that runs through the "square" the hands are on, is this the taper pin you mentioned?
  4. harold bain
    39,893
    Yes. It's hard to see it in your picture. You will need to straighten it and pull it out to remove the hand, if you need the hand removed.
  5. Orafist
    Mar 2, 2012
    35
    #25 Orafist, Mar 7, 2012
    thank you Harold, I think that hand will need to come off. if I could trouble you with another question, if you look at the right side of my movement above the hammers there seems to be an adjustable "bar" could this be a selector for different chimes? as a related question is it ok to run in extended silent mode, like leaving it on silent for days??
  6. harold bain
    39,893
    Your clock only has Westminister chimes, not enough chime rods for others. The black bar piece at the bottom right is to lock the chime rods for transportation, and should not touch the rods when using the clock. It shouldn't hurt the clock to put it on silence, as long as the chime correction is working properly.
  7. Orafist
    Mar 2, 2012
    35
    yes you helped me understand the purpose of the black bar for chime storage, by "bar" I mean the brass bar on the right hand side of the movement above the hammers
  8. harold bain
    39,893
    If you mean the one on the left side in your picture, I don't think it does anything as it sits now. It looks like it would have been a chime hammer arrestor to silence them.
  9. Orafist
    Mar 2, 2012
    35
    Yes Harold, I did mean the brass bar on the left, thank you.
Similar Threads - Seeking information mantel Forum Date
Pearl Grandfather Clock - New acquisition seeking information General Clock Inquiries Jan 8, 2017
Seeking more information on this old Simplex wall clock General Clock Inquiries Dec 31, 2016
Seeking some information on this clock General Clock Inquiries Dec 9, 2016
Seeking Information of Old German Clock General Clock Inquiries Jun 30, 2016
New Clock, seeking information? General Clock Inquiries Mar 26, 2016
