Seeking German or Austrian Uhrmacher with initials VZ circa 1700
Discussion in 'General Clock Discussions' started by Jim Duncan, Mar 15, 2017.
  1. Jim Duncan
    Jim Duncan Registered User
    Donor NAWCC Member
    May 31, 2011
    328
    Central Coast of California
    #1 Jim Duncan, Mar 15, 2017
    The newest old clock now in the house is a zappler (fast moving pendulum) with a painted iron dial and small brass movement. The rear plate of the movement is engraved with the year 1704 and the initials V Z, presumably the maker.
    Can anyone suggest a clockmaker (uhrmacher) in Germany or Austria from that period?
    In the photos you’ll see the movement mounted into a handmade carved stand. The seller thought the stand only dated to about 1900 and I can find no reason to differ. On the back of the steel face plate (dial pan?) is a U-shaped bracket that I expect was used to mount the clock on a rod held to a weighted block or wall bracket. The dial is 11.5 cm/4.5” in diameter.
    An interesting feature is that the mainspring is wound directly from the front at the hand arbor (also the mainspring winding arbor). One can remove the hand easily as it is held by friction. The collet or hub that carries the hand is a friction slip piece that allows an easy reset after winding. First time I’ve seen this approach.
    This seems to me a ‘happy’ clock because as soon as I took it out of the shipping box and removed the plastic sheet between the pendulum and the dial it began to run. The beat wasn’t perfect but it ran for 26 hrs after putting a spacer under one foot of the stand to improve the beat.
    Any help in determining a maker would be much appreciated.
    Jim[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. Jim Duncan
    Donor NAWCC Member
    May 31, 2011
    328
    This entry is to close out my own thread. After no takers on the Message Board I requested Research help from the NAWCC folks.
    In Jurgen Abeler's book "Meister der Uhrmacherkunst" (Masters of Clockmaking) they found Vincentius Zimmermann from Landshut, Germany (Bavaria) working c1705.
    I thought this a good match and thanked them for the service.
    Jim
Similar Threads - Seeking German Austrian Forum Date
Seeking Information of Old German Clock General Clock Discussions Jun 30, 2016
Seeking ID of Semi-modern German Movement - Howard Miller General Clock Discussions Nov 22, 2013
Seeking information on old German wind-up clock by maker "Lord" General Clock Discussions Aug 20, 2013
Seeking info on this German(?) clock (photos attached) General Clock Discussions Oct 16, 2010
Seeking info about this German clock General Clock Discussions Aug 16, 2009
