Seconds hand for 21J Bunn Special replacement doesn't fit
Discussion in 'Watch Repair' started by mtucker, Oct 7, 2019.
  1. mtucker
    mtucker Registered User
    Apr 13, 2019
    I decided to replace the second hand on my inherited Bunn Special ( here is my thread on it Inherited Bunn Special B&O Railroad ). Someone told me the second hand was off an Elgin watch and I confirmed that with some Googling. The second hand I bought was advertised for a Hamilton, but I knew Hamilton bought Illinois shortly before my watch was made (it is a 1929) so I took a chance on it. It looks like what I thought is the correct second hand for my watch, but the opening is smaller than the opening on the Elgin second hand and it won't fit on the seconds shaft.
    My questions are:
    1. visually (shape), is that the right second hand
    2. If yes, do some of the second hands have a different fitting pressed in and that is why the opening is too small?
    Thanks,
    Matt
  2. Chris Radek
    Chris Radek Registered User
    Apr 13, 2014
    552
    183
    Watchmaker (now accepting new customers)
    Lincoln, NE, USA
    It's very common to have to ream second hands to fit. A tapered reamer should be used, and with care you can get the friction fit perfect.
  3. musicguy
    musicguy Moderator
    NAWCC Member Sponsor
    Jan 12, 2017
    5,685
    2,753
    New York State
    Moving to watch repair
    Rob
  4. mtucker
    Apr 13, 2019
    Thanks for the information. It would take a bit of reaming since the opening on the Elgin hand doesn't look much smaller than the entire protrusion on the Hamilton hand. I noticed the Elgin hand has a cut on the cylinder piece that press fits on to let it expand some when pushed on. The Hamilton cylinder piece doesn't appear to have a way to let it spring open.
    Thanks. Still a little new on this forum.
    I can keep my eye on Ebay for another second hand off an Illinois watch. Does anyone know if the Hamilton version and the version used on the Illinois differ at all? They visibly look identical in shape.
    Thanks,
    Matt
  5. terry hall
    terry hall Registered User
    NAWCC Brass Member
    Apr 12, 2001
    6,990
    345
    Central North Carolina
    in your second image i see something....
    remove the dial, examine the 4th wheel post... ensure the OLD fitting for the second hand is not still attached to the post......
    sure appears to be in the image. I know if you view it without the dial on the movement it will be apparent....
    do this before broaching the hand....
  6. mtucker
    Apr 13, 2019
    I see what you are saying. I'll check it out. Thanks very much.
  7. mtucker
    Apr 13, 2019
    I have never taken a pocket watch apart before, but some Youtube videos helped give me the confidence to remove the movement and dial. It isn't obvious to me if the old fitting is still attached, but I don't have anything to compare it to. I have a microscope at work which helps a lot. It is hard to take pictures through the microscope, but I got a decent shot at an angle. You see so much more at an angle compared to straight on. Both pictures are below. Any feedback if the old fitting or adapter is still there? If it takes anymore disassembly, I will probably send it to a person that specializes in american pocket watches.
    Thanks,
    Matt
  8. richiec
    richiec Registered User
    Feb 24, 2007
    6,677
    499
    automotive warranty inspector
    Brick, Ocean, NJ
    Don't see anything on the shaft, it is bare.
  9. mtucker
    Apr 13, 2019
    OK, thanks. It looks bare to me too. I put the Elgin second hand back on. Although wrong, it is about the same blue color as the minute and hour hand. Next time I have the watch serviced, I'll see if they can get a correct second hand and put it on there.
    Matt
  10. Rob P.
    Rob P. Registered User
    Dec 19, 2011
    1,916
    132
    California
    Give the repairman the seconds bit you have and ask him to install it. It's just a matter of reaming to size and he should have the tools to do that task.
  11. Marty101
    Marty101 Registered User
    Oct 28, 2007
    678
    98
    Retired-bad back but still movin'.
    Niagara Falls,N.Y.
    Rob is correct about the reaming. And it isn't much;it shouldn't take but 30 seconds or so. I'm sorry you've been through so much trouble with this-I assume you bought that hand from me-?-
    It is a touchy thing working with friction fit parts. I have found reaming second hands that should fit to be mostly cleaning,not resizing.
  12. mtucker
    Apr 13, 2019
    Thanks for the reply. I don't think I bought it from you. The Ebay auction for the hand lists the seller's location as Saint Jacob, Illinois. In a way, I'm glad it didn't fit. It pushed me to take the movement out of the case and pull the dial off so now I know how to do some of the the basics.
    Would you mind taking a look at the very first picture I posted on this thread? It shows the two second hands side by side. The correct looking hand looks like the opening it is considerably smaller than the Elgin that fits. If you think it is OK, then I may try to get a reaming tool and do it myself.
    Thanks,
    Matt
  13. Marty101
    Oct 28, 2007
    678
    98
    Niagara Falls,N.Y.
    Matt,sorry I missed you.
    The pipe hole dimensions do look different,but that can be deceiving. Get that set of broaches.
