Just a query. I'm working on a hermle movement with the secondhand feature. The long arbor that projects outwards and through the dial, has been very slightly bent. It is slight though but you can see it wobble slightly when allowing the time train to run.
I am just wondering if this will cause a problem. Obviously it has been caused by an heavy handed individual trying to locate the seconds hand!!!
I just wonder if its fine to leave and use as is?
