Most visitors online was 1990 , on 7 Feb 2022
I don't see how you can "modify" an Ollie Baker. I think you just have to reverse your thinking and/or how you put the spring/barrel into the winder.Springs wind backwards, need to modify my spring winder.
I generally don't like chime clocks, they are noisy.I'm still scratching my head as to why this is called a "noise maker".So it chimes... Did I miss what the model name for this clock??
Kurt
Please note this platforms' escape wheel rotates counterclockwise. Generally the potence shroud can be carefully rotated however the balance, pallet and escape wheel must be removed first. Timesavers Box 12700 Scottsdale, AZ 85267 USA 1-800-552-1520 info@timesavers.com www.timesavers.com |
