Schatz Mariner
Discussion in 'Clock Repair' started by strangerthings, Mar 19, 2020.
  1. strangerthings
    strangerthings Registered User
    Jun 22, 2019
    130
    I bought this set recently and it seems like the clock is over turned. Both key positions won’t turn and the clock won’t run. Any ideas? Thanks!
    84C69B10-701B-4FF2-9B41-02324E2E5322.jpeg 6CFB1D8C-59CA-4F0E-902B-77B36E3C8DBC.jpeg 22467F4F-5C81-43C0-92B9-5EC2C94AE638.jpeg D70C2286-1D43-4C7B-91BB-1567139B045D.jpeg
  2. bruce linde
    bruce linde Technical Admin
    6,342
    691
    oakland, ca.
    i think you mean overwound... but you can't really overwind clocks. if you wind them too far, you break something... either the mainspring, the hook holding it, or (for weight driven clocks) the weight cord, etc.
    my oft-stated rule of thumb is: if you don't know when it was last serviced, it needs it.
    your clock might be fine, but with parts rusted or frozen in place. and, there might be other issues.
    the only way to know for sure it to let down the mainspring(s), fully disassemble, clean, address all issues (pivots, pivot holes, inspect/clean/grease mainspring, clean again, reassembly, oil, test, etc.
  3. Kevin W.
    Kevin W. Registered User
    22,259
    319
    If its like mine, it has lots of wear and has not been serviced for a long time. Its not a easy clock to work on and the platform escapement will need to be cleaned and oiled for the clock to work. Over wound is a myth and clocks dont run when fully wound, then they need service. If you plan to let down the power your self. Read up on how to do it. Word of caution, dont hold the key with your hand.
  4. strangerthings
    Jun 22, 2019
    130
  5. strangerthings
    Jun 22, 2019
    130
    What is the on/off switch for? Also, I opened it up and I saw a part that was looking like it was sticking. I gave it a little push and it’s been ringing for about the past 5 minutes not stop. However, it seems like the ticking comes and goes.
  6. glenhead
    glenhead Registered User
    Nov 15, 2009
    1,111
    154
    Telecom Engineer
    Williamson County, Texas
    The on-off switch is to silence the bell. As the others have said, if it doesn't run it needs an overhaul. Mine will run about ten years between overhauls, so it's a good investment. Granted, mine has read 1:17 for the last two years - the mainspring broke while winding it, and my paying backlog is so long that I don't have time to fix it. (That's why only two of my nine clocks run right now. Sigh.)
    Glen
  7. strangerthings
    Jun 22, 2019
    130
    Copy, thank you
  8. THTanner
    THTanner Registered User
    Jul 3, 2016
    2,563
    177
    Carson City, Nevada
    Some of these will tend to strike non stop if they are not supported in the proper 12 O'clock High position - If it is set up 12 high and it still strikes non stop then you will have to proceed with a full service. Whatever was stuck and you freed up is probably the issue and probably needs service regardless.
