Hi to all of you!
I am fairly new to getting old clocks running angain and got caught by the efficiency of the 400 day clock movement, have a Kern and a nice Schatz put back into running, more luck than knowledge I guess.
I got a nice box, containing a small Schatz clock with a JUM/7 movement wich looked like it was soaked in oil several years before, took it apart as far as I trust myself to go, which means, the main spring has stayed in the drum, and not as far as I would like to because I cannot take the central axe of the minute gear wheel out of the front platine because the small gear wheel that connexts to the hour wheel gearing is in the way.
Whom of you can tell me how to get this wheel off the shaft, I really need to clean the hole and the surrounding of it of the platine.
Another question is about the tension of the hands; is there no spring washer mounted in this clock, the hands move very lightly and the small nut at the minute shaft looked only to keep the minute hand fixated on the axe.
Paul Tummers.
Paul Tummers.
