I have this clock the elexacta that doesn't swing? I have had this clock for about a year and it just hangs on the wall and does nothing.Thought it might be time to find out what the heck is wrong.The clock winds and the small compond pendulum moves back and forth but the clock its self doesn't swing if you give the clock a swing it will swing for a while and sounds in beat but the swing of the small pendulum gets out of sink with the clock and then stops? I wil try to post a picture of the small pend. and if you look at the top side of it there you well see a hole with wear marks around it that looks like some type of weight or something should be there. it just seems like it is out of balance. but beat sounds good.
does any one have one of these where they can look and see or rememeber about the small pend.
Thanks Harold
http://pictures.aol.com/ap/welcome.do
Thanks Harold
