SCC Fashion #4 BPH
KyleG
Nov 4, 2006
99
Does anyone have the correct BPH for the SCC Fashion #4? TIA
17,155
3,007
There will be nice ghost marks (on the back of the calendar dial, made by the old bob) that you can go by. Otherwise: Shorter = Faster & Longer = Slower, always works for me ... Willie X
48,936
2,695
If you have a beat counter, just mark a starting point for the minute hand, start the counter and let it count for about 3 revolutions of the minute hand. Then divide the number of beats by the number of revolutions and you'll have a pretty accurate BPH for the clock. No need for the pendulum if it will run without one, but any pendulum will work for this.
wow
Jun 24, 2008
6,582
1,048
77
Pineville, La. (central La.)
I have an original pendulum
Good. I have a #4T but do not have the original pendulum. I just experimented with parts and made one as near the original as possible. I just figured out the rate by adjusting. Yours is not the weight and size of mine so I’m no help.
Bill Stuntz
Apr 6, 2012
5,018
65
73
Columbus. OH
Am I wrong? The size/weight of the pendulum doesn't matter. If it's the same movement bph will be the same. Will, if you know that number it might help him get it into the right ballpark.
wow
Jun 24, 2008
6,582
1,048
77
I have not put my meter on it. Just got it adjusted manually. I’ll do it tomorrow and post it.
17,155
3,007
Tip, a half unfolded paper clip with a little hook bent at one end will help you get the bob on and off. If you drop the bob, it may be more of a problem than you may think ... :oops: Willie X
176,432
1,544,327
53,306
Boriss_k
1,064
3,031
