Sangamo clock motor
Discussion in 'Electric Horology' started by Kevin W., Sep 23, 2019.
  1. Kevin W.
    Kevin W. Registered User
    21,802
    240
    The motor in my Sangamo clock is 25 cycles. From what i have experienced and learned, is that 25 cycles will not wind the clock main spring, and it needs to be 60 cycles.I have been told the coils of the motor could be rewound to make the motor run at 60 cycles. One shop i asked has told me this will cost 450 dollars.
    I will enquire at a few more shops but thinking perhaps better to just replace the motor, original to Sangamo clocks, with a 60 cycle motor, hope i can find one.
  2. David S
    David S Registered User
    Dec 18, 2011
    7,173
    236
    Brockville, On Canada
    Can you show a picture of this motor Kevin?
    David
  3. Kevin W.
    21,802
    240
    Here are some pics of the clock with motor attached.
    70779007_10156579943717913_3404072348733669376_n.jpg 71081527_10156579918807913_8496687510519283712_n.jpg
  4. Uhralt
    Uhralt Registered User
    4,046
    413
    Maybe a moderator can move this to the "Electric Horology" section for better exposure.
    Kevin W. likes this.
  5. bangster
    bangster Moderator
    19,384
    341
    Done.
    bangster
    moderator
  6. Kevin W.
    21,802
    240
    Thanks Bangster.
  7. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,285
    104
    Aerospace Engineer (Ret.)
    San Antonio, TX
  8. Kevin W.
    21,802
    240
    Thanks Kurtin, yes i have found the site and contacted him.
  9. Kevin W.
    21,802
    240
    I contacted Les again. He says should be no problem getting a motor from his bone yard of old motors that he has. I will post more later and ask questions about repairs sometimes too.
  10. Kevin W.
    21,802
    240
    Update. I bought a motor and a power cord for my clock. I put the motor on and it wound the main spring okay. But clock wont start. Les has been a great help and has said there will be wear in pivot holes. And there is. Also about 12 bushings most likely to put in, and also mentioned pivots will need to be burnished. As these clocks need all the power they can get to run the escapement.
