Sandoz Pocket watch
Discussion in 'European & Other Pocket Watches' started by realfire, Jun 15, 2020.
  1. realfire
    realfire Registered User
    Feb 2, 2020
    32
    13
    Hello all,
    I recently picked up this vintage sandoz pocket watch at an estate sale for 5 bucks lol. I can't tell if it works because it dosen't have the winding key and it looks like its missing glass and one of the hands? If anyone knows about this piece I would really appreciate any feedback and if someone knows what size winding key I should be looking for. I figured it's worth at least 5 bucks in silver hopefully.
    Thanks in advance!
    20200615_095957.jpg 20200615_100616.jpg 20200615_100548.jpg 20200615_101355.jpg 20200615_101416.jpg
  2. Dr. Jon
    Dr. Jon Moderator
    Dec 14, 2001
    5,835
    515
    Aerospace Engineer
    New Hampshire
    #2 Dr. Jon, Jun 15, 2020
    Sandoz was a good maker. Form the inscription it seems you watch is a small cylinder movement. If it runs don't run it much as there are very hard to repair.
    Finding the right key is trail and error. Sets of keys are available very inexpensively. Thekeys are do not last long in use but are probably good enough for occasional use. There are also universal keys with adjustable jaws that work OK and in a pinch you can wind with a pin vise, DO not wind much one turn at most and if the watch is Ok, it will run.
  3. eri231
    eri231 Registered User
    Jan 13, 2012
    1,391
    232
    torino italy
    A. Sandoz & Fils was Ami Sandoz in Le Locle (1815-1857) in 1835 he moved to Geneva. father of Alfred and Paul the first watchmaker the second case assembler
    regards enrico
    Dr. Jon likes this.
  4. realfire
    Feb 2, 2020
    32
    13
    Thanks so much for replying, any idea on where I can find sandoz serial number database? Can't seem to find anywhere and wondering how old this is.
  5. realfire
    Feb 2, 2020
    32
    13
    Here is the movement by the way
  6. gmorse
    gmorse Registered User
    11,404
    1,655
    Retired from Xerox
    Hi realfire,
    In these Swiss watches the number in the case usually only refers to that case, it has no correlation with the movement, which itself doesn't appear to be numbered. If the movement isn't numbered you have to rely on a rough estimate based on the movement layout, which suggests the third or fourth quarter of the 19th century.
  7. jess tauber
    jess tauber Registered User
    Dec 24, 2017
    137
    32
    I have a 16s Ami Sandoz lever (standard bar) movement which runs nicely, though it only has an hour hand. The name on the mvmt side is so tiny you can't see it without magnification. No pics, though. Glad to see some references to the maker.
    Jess Tauber
  8. Maren
    Maren Registered User
    Feb 22, 2019
    14
    Hello
    I need help about one watch, on dial is marked as "Georges Jules Sandoz - La Chaux de fonds"
    but movement is marked as LE COULTRE & CIE
    Take a look on photos
    Is this non original case?
    What you think?
    On movement picture take a look on upper left corner, you will see Le coultre & cie remark
    Your opinion about this watch? Thanks
    WP_20200720_20_56_02_Rich.jpg WP_20200720_20_56_31_Rich.jpg WP_20200720_20_55_31_Rich.jpg WP_20200720_20_55_14_Rich.jpg
