Sand casting Help
Discussion in 'Clock Case Restoration and Repair' started by roman16, May 18, 2017.
  2. Welcome to the new home of the NAWCC Message Board
    We are glad to see you have found us Guest. If you like what you find here, please let your friends know about us.
  1. roman16
    roman16 Registered User
    Mar 4, 2006
    96
    Hi. I need a brass or bronze clock foot sand cast. Years ago a had a contact for a sand caster who did fine work but he has seen retired. Any recommendations? Thanks.
  2. novicetimekeeper
    Jul 26, 2015
    4,716
  3. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    884
    If you happen to be in the UK, your might try this web site for help:
    http://optimumbrasses.co.uk/
    I live in the US, and they have done work for me before, that I have been quite happy with!
    Best,
    George N.
Similar Threads - Sand casting Help Forum Date
Casting replacement finials for French Pendule Religieuse case Clock Case Restoration and Repair Feb 12, 2017
Ansonia Cast iron case Clock Case Restoration and Repair Jan 26, 2016
Casting Spelter Parts Clock Case Restoration and Repair Mar 7, 2014
Cast Iron Case Clock Case Restoration and Repair Aug 27, 2013
Sanding Shellac coats Clock Case Restoration and Repair Oct 2, 2005
