Good afternoon gentlemen,
I am a complete newbie and this is my first post so please be gentle with me.
I have a 400 day clock which has been in my wife`s family for many years, my initial thoughts were that it was a Kundo, but having read some posts regarding misidentification I now believe it is a S und P. I have attached some pics (hope the quality is ok).
If I am correct could any of you learned chaps advise as to the correct size of suspension required?. The bottom block is missing but top block and fork are intact so I will be able to get the correct spacing for the replacement. Regarding the bottom block, I have seen some images which show S and P clocks with a distinctive teardrop shaped bottom block, was this standard for all these clocks as I will need to fit a generic rectangular block which I assume will work ok as I am more interested in getting the clock running rather than being too fussed about originality.
I would also be interested in the manufacture date of the clock -Serial No 25866 which appears to be hand stamped.
Finally, at the risk of upsetting any purists, could anyone recommend a metal polish (available in UK) which will give a good shine to the plates and carcass of the clock?, some people seem to use Brasso whereas others seem to have issues regarding the residue it leaves.
I would greatly appreciate any advice you can give.
Thanks,
John
Thanks,
John
