S/T-SCC Fashion No. 4 Pendulum Issue
Discussion in 'Clock Repair' started by KyleG, Jul 6, 2018.
  1. KyleG
    KyleG Registered User
    Nov 4, 2006
    91
    I have a SCC Fashion No. 4 pendulum that the bob is frozen on the stick - I'm unable to move it up or down. I suspect the pendulum is supposed to have a locking thumbscrew on the back of the bob, but if so, this is missing/broken off. See pics. Does anyone have a correct/funtional bob that can share a picture? And if possible measure the thread size of the locking screw. Appreciate any and all assistance.
    Kyle
  2. KyleG
    Nov 4, 2006
    91
    Sorry, I couldn't figure out how to include picture in original post.
  3. Uhralt
    Uhralt Registered User
    4,849
    575
    I don't think that there should be a set nut. Probably the pendulum bob is simply stuck. I would suggest to unscrew the nut below the bob for a quarter of an inch. Then. hold the bob in one hand and give the steel pendulum rod a blow with a wooden hammer, a brass hammer or a rubber hammer. That should loosen the bob and you should be able to regulate the clock.
  4. bruce linde
    bruce linde Technical Admin
    6,766
    821
    oakland, ca.
    i agree... i've not seen a thumbscrew on a ST bob before... but if it turns out that there is some kind of screw or pin you could always drill it out...
  5. wow
    wow Registered User
    Jun 24, 2008
    4,133
    291
    Retired Music Minister
    Pineville, La. (central La.)
    Show us a photo of the front, please. #4’s had a special pendulum with factory markings/etching on it.
  6. KyleG
    Nov 4, 2006
    91
    Not much of the design left, most has been polished away over the years.
  7. wow
    wow Registered User
    Jun 24, 2008
    4,133
    291
    Kyle, I have a #4, but the pendulum is not original. I have never seen a pendulum like yours with a lock screw on it. Perhaps a soaking with something like silicone will free up the bob. There is probably corrosion on the bob and the wood is probably swollen. It should break loose after soaking a while.
  8. KyleG
    Nov 4, 2006
    91
    With all responders unanimous in their opinions that this bob does not have any kind of locking nut on the back, I took Uhralt's suggestion to back off the rating nut and tap the rod with a hammer. A couple of light taps on the metal rating rod and I was able to get the bob to grudgingly move. I was then able to move the bob back to its original postion by hand pressure. Still could not adjust the bob using just the rating nut. I'll need more work to free the bob before being able to regulate timing easily.
    Thanks to all for their input.
    Kyle
